Algebra word problem: finding the distance
In summary, the problem involves finding the distance $d$ given the speeds for walking, riding, and driving, and the time spent on each activity. We can represent this with a diagram and use equations to solve for $d$. When we add the equations, we get $d=60$, which is the answer to the problem.
NotaMathPerson
83
Hello! Please help continue solving tye problem I got stuck.
This is my attemptlet $d=$ length of the circuit
$\frac{60}{a}$mph --- speed for walking
$\frac{60}{b}$mph ----speed for riding
$\frac{60}{c}$mph ---- speed for driving
$d = \frac{60}{a}t_{1}+ \frac{60}{b}t_{2} + \frac{60}{c}t_{3}$
From here I cannot continue. Kindly help me. Thanks!
Mathematics news on Phys.org
I would begin this problem by drawing a diagram:
Now, what we want to find is the distance $d$ where:
\(\displaystyle d=x+y+z\)
Using the information given in the problem, we may write:
\(\displaystyle \frac{x}{a}+\frac{y}{b}+\frac{z}{c}=c+b-a\)
\(\displaystyle \frac{y}{a}+\frac{z}{b}+\frac{x}{c}=a+c-b\)
\(\displaystyle \frac{z}{a}+\frac{x}{b}+\frac{y}{c}=b+a-c\)
What do you get when you add these 3 equations?
This is what I get
$\left(x+y+z\right)\left(\frac{1}{a}+\frac{1}{b}+\frac{1}{c}\right)=a+b+c$
NotaMathPerson said:
This is what I get
Yes, good! (Yes)
I chose to write this as:
\(\displaystyle d\left(\frac{1}{a}+\frac{1}{b}+\frac{1}{c}\right)=a+b+c\)
Now, solve for $d$. :)
MarkFL said:
Yes, good! (Yes)
I thought of it too. But solving for d only gives me letters. In my book the answer is 60 miles. Why is that?
And can you explain why do we need to add the 3 eqns? Thanks.
I didn't read the question thoroughly (regarding the 3 velocities being given in minutes instead of hours)...what we get instead is the system:
\(\displaystyle \frac{ax}{60}+\frac{by}{60}+\frac{cz}{60}=c+b-a\)
\(\displaystyle \frac{ay}{60}+\frac{bz}{60}+\frac{cx}{60}=a+c-b\)
\(\displaystyle \frac{az}{60}+\frac{bx}{60}+\frac{cy}{60}=b+a-c\)
Now when we add the equations, we obtain:
\(\displaystyle \frac{d}{60}(a+b+c)=a+b+c\implies d=60\)
FAQ: Algebra word problem: finding the distance
What is the formula for finding distance in an algebra word problem?
The formula for finding distance is: Distance = Rate x Time. This is known as the Distance Formula.
How do I know which values to plug into the distance formula?
You need to identify the known values in the word problem. The rate is typically given in terms of speed (miles per hour or kilometers per hour) and the time is given in hours. Make sure to convert any given units to match the units in the formula.
Can the distance formula be used for any type of problem?
No, the distance formula is specifically used for problems involving constant speed. If the speed is changing, you will need to use a different formula, such as the Average Rate formula.
What do I do if there are multiple distances to be found in a word problem?
In this case, you will need to set up multiple equations using the Distance Formula for each distance. You can then solve the system of equations to find the values for each distance.
Is it necessary to include units in the answer when using the distance formula?
Yes, it is important to include units in the answer to indicate the distance unit (miles, kilometers, etc.). This helps to ensure that the answer is correct and makes sense in the context of the problem.
