Algebraic Closure of Laurent Series
In summary, my professor says that the given thing is "close" to the algebraic closure, and he doesn't feel certain enough to say for sure what the algebraic closure precisely is. However, it seems fairly easy to show that the given extension is in the algebraic closure.
AKG
2,567
Define:
[tex]\mathbb{C}((t)) = \{t^{-n_0}\sum_{i=0}^{\infty}a_it^i\ :\ n_0 \in \mathbb{N}, a_i \in \mathbb{C}\}[/tex]
What is its algebraic closure? My notes say that it is "close" to:
[tex]\bigcup _{m \in \mathbb{N}}\mathbb{C}((t))(t^{1/m})[/tex]
where [itex]\mathbb{C}((t))(t^{1/m})[/itex] is the extention of the field of Laurent series by the element t1/m. Is this in fact the closure? If not, what is it? Also, how would I prove that something is the algebraic closure of this field? I mean, if X is the algebraic closure, then one thing is to prove that every polynomial over C((t)) has a root in X, but how do I show that there is no intermediate field between X and C((t)) that also has this property? I.e. it's one thing to show that a field X contains the algebraic closure of another field Y, but how do I show that it IS the algebraic closure of Y?
Can you write down a simple set of generators for your extension field, to simplify the problem?
Or maybe use the ol' set theory trick: instead of trying to show that your extension field is an algebraic closure, try to show that it's a subset of an algebraic closure.
For your first hint, maybe you mean {t1/p | p prime}, or even {t1/m | m natural}. And the algebraic closure would have to contain these, so the extention generated by these is contained in the algebraic closure. This actually wasn't that hard, and now that I think about it, I think something like this was in my notes. What's confusing me is that my professor said that the given thing was "close" to the algebraic closure, and he didn't feel certain enough to say for sure what the algebraic closure precisely is.
So I think, given the above, it's relatively easy to show that the given extention is in the algebraic closure. But is the algebraic closure in it? That is, does every polynomial with coefficients in the set of Laurent series have a root in this union of one-element extentions?
My professor sort of did this. He took an arbitrary polynomial. First he supposedly reduced the problem to one where the coefficients of the polynomial have no poles. A root x of this polynomial would be a Laurent-ish series in t1/m for some m. The coefficients of this series would be complex numbers. Using a method of undetermined coefficients approach, he gave an idea for how these coefficients could be determined. Is this the right idea?
Incidentally, these are called Puiseux series.
Anyways, we're talking formal Laurent series, etc, right?
It's easy to reduce the problem to where there are no "poles" through a change of variable -- make the substitution x = tn y for a sufficiently large n.
It sounds like your professor's approach is just a variation on a basic theme: you want to incrementally construct a solution one term at a time (or more).
My gut says that we want to prove the following conjecture:
Let f(x, t) be an element of C[[t]] [x] of degree n in x. Then, the polynomial f(x, tn) has a solution in C[[t]] [x]. (Or maybe we want that exponent to be n!)
And we want to find said solution by first constructing a solution modulo (t), and then modulo (t²), and so forth. Or, maybe we want to do it first modulo (tn), and then modulo (t2n), and so forth.
Hensel's lemma might even solve the whole thing for us!
this is a standard result in algebraic curves by robert walker, or is easy using complex analysis for convergent laurent series.
thm 3.1, walker, algebraic curves, page 98, "the field of fractional power series is algebraically closed".
the point here is essentially the existence of local parametrizations of any point of an algebraic plane curve, even a singular point.in the complex case, just project a nbhd of the point onto the z axis, and prove that in the complement of the singular point, it is a d sheeted covering space for some d.
hence by classification of covering spaces of the punctured disc, this projection is equivalent to the holomorphic map z^d away from z=0.
but then by the riemann extension theorem, this parametrization extends to the origin as well. i.e. the map z-->z^d lifts to a holomorphic map from the disc onto a nbhd of the singular point, which is an isomorphism from the punctured disc to a punctured nbhd of the singularity, and is also holomorphic at 0.the algebraic approach is to consider the equation of the plane curve as polynomial in w with coefficients which are polynomials in z, and then to ask for a "root" of this polynomial.
such a root will be an expression w which is locally a dth root of a power series in z, or some such, i.e. lifting the d to 1 projection of the curve to a parametrization of the curve is like taking dth roots of the z values of the porojection.
but this is always confusing to me.
FAQ: Algebraic Closure of Laurent Series
1. What is the definition of algebraic closure of Laurent series?
The algebraic closure of Laurent series refers to the process of extending the field of Laurent series to include all algebraic elements, i.e. elements that satisfy a polynomial equation with coefficients in the field.
2. Why is the concept of algebraic closure of Laurent series important?
The algebraic closure of Laurent series is important in fields such as algebraic geometry and number theory, where it allows for the study of algebraic objects over fields of Laurent series.
3. How is the algebraic closure of Laurent series related to the concept of algebraic closure of fields?
The algebraic closure of Laurent series can be seen as a natural extension of the concept of algebraic closure of fields, where instead of extending a field to include all algebraic numbers, we extend the field of Laurent series to include all algebraic elements.
4. What is the difference between algebraic closure of Laurent series and algebraic closure of power series?
The algebraic closure of Laurent series extends the field of Laurent series, which includes both positive and negative powers of the variable, while the algebraic closure of power series only extends the field of power series, which includes only non-negative powers of the variable.
5. Can the algebraic closure of Laurent series be constructed explicitly?
Yes, the algebraic closure of Laurent series can be constructed explicitly by systematically adding algebraic elements to the field of Laurent series until all algebraic elements are included. This is known as the algebraic closure construction process.
