Algebraic equation problem, rectangular flower bed
  • MHB
  • Thread starter mathlearn
  • Tags
    Rectangular
In summary: No, this is what I had in mind:Begin with:x+10=4x-y\tag{1}x+20=2x+3y\tag{2}Now, multiply (1) by 3:3x+30=12x-3y\tag{1}x+20=2x+3y\tag{2}then add (1) to (2) thereby eliminating $y$ and obtaining an equation in $x$ alone.4x+50=14xNow solve for $x$...:D
mathlearn
331
Any ideas on how to begin ?
Mathematics news on Phys.org
You can set up two equations in two unknowns:
x + 10 = 4x - y
x + 20 = 2x + 3y
Can you solve this system for x? Do you see why we only need the value of x to find the area of the flower bed?
x + 10 = 4x - y
x + 20 = 2x + 3y
Y = 6.25 ,x = 1.58
That's incorrect. Solve
x + 10 = 4x - y
for y then substitute that value for y into
x + 20 = 2x + 3y
and solve for x.
Please show your work.
x + 10 = 4x - y
x + 20 = 2x + 3y
and solve for x.
x + 10 = 4x - y
x + 10 -4x = - y
-3x + 10 = - y
3x - 10 = y
Now substituting that value for y,
x + 20 = 2x + (3x-10)
x + 20 = 5x - 10
-4x=-30
x = 7.5
x + 20 = 2x + 3(3x - 10)
Another method for solving the system for $x$ is elimination. So, you can start with the system Greg posted:
\(\displaystyle x+10=4x-y\tag{1}\)
\(\displaystyle x+20=2x+3y\tag{2}\)
Now, multiply (1) by 3, then add it to (2) thereby eliminating $y$ and obtaining an equation in $x$ alone. :D
\(\displaystyle x+10-4x=-y\tag{1}\)
\(\displaystyle -3x+10=-y\tag{1}\)
Multiplying this equation by 3
\(\displaystyle -9x+3y=-30\tag{1}\)
Moving x to the left hand side of the equation,
\(\displaystyle -x+3y=-20\tag{2}\)
Hope the equations are correct to move on to elimination.
Begin with:
\(\displaystyle 3x+30=12x-3y\tag{1}\)
\(\displaystyle 4x+50=14x\)
FAQ: Algebraic equation problem, rectangular flower bed
What is an algebraic equation problem?
An algebraic equation problem is a mathematical problem that involves solving for an unknown variable using a combination of numbers, variables, and mathematical operations such as addition, subtraction, multiplication, and division.
How can I solve a rectangular flower bed algebraic equation problem?
To solve a rectangular flower bed algebraic equation problem, you will first need to identify the unknown variable, which could be the length, width, or area of the flower bed. Then, you can set up an equation using the known values and the unknown variable. Finally, you can use algebraic operations to solve for the unknown variable.
What are the most common variables used in a rectangular flower bed algebraic equation problem?
The most common variables used in a rectangular flower bed algebraic equation problem are length (l), width (w), and area (A). These variables represent the dimensions of the flower bed.
Can I use algebraic equations to solve other types of gardening problems?
Yes, algebraic equations can be used to solve a variety of gardening problems, such as determining the amount of fertilizer needed for a given area, calculating the volume of soil needed for a raised garden bed, or finding the optimal spacing for plants in a garden.
Are there any tips for solving a rectangular flower bed algebraic equation problem more efficiently?
One tip for solving a rectangular flower bed algebraic equation problem more efficiently is to draw a diagram or use a visual aid to represent the problem. This can help you better understand the problem and identify the known values and unknown variable. Additionally, it is helpful to double-check your work and make sure your final answer makes sense in the context of the problem.
