MHB Algebraic Expressions Simplified
  • Thread starter Thread starter loraboiago
    Expressions
In the equation 3x(x-5)=0, the zero-factor property states that if the product of two factors equals zero, at least one of the factors must also equal zero. This means either 3x=0 or (x-5)=0. Solving these gives the values x=0 and x=5. The calculation for x=5 comes from setting (x-5)=0 and solving for x. Understanding this property is essential for solving algebraic expressions effectively.
loraboiago
How does 3x or (x-5) equal 0 in the statement 3x(x-5)=0? I don't understand the logic behind it. Thank you!
Mathematics news on Phys.org
If you have the statement:
$$a\cdot b=0$$ where $$a\ne b$$
Then the only way it can be true is if either $$a=0$$ or $$b=0$$. This is called the zero-factor property.
Thank you Mark for the quick and helpful response. The answer to this question went on to explain "3x(x-5)=0 provides an equation in which at least one of the expressions 3x or (x-5) is equal to 0. That translates into two possible values for x: 0 and 5."
I understand how one can equal 0 (thanks to you!), but how do I calculate the other possible value as being 5?
I would look at it as 3 factors being equal to zero:
$$3\cdot x\cdot(x-5)=0$$
Now, set all factors involving $x$ equal to zero, and then solve for $x$ in each equation:
$$x=0$$
$$x-5=0$$
The solutions to these equations will give you the solutions to the original equation.
$$x=0$$
$$x-5=0$$
Ah got it! You are awesome. Thank you :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
