Algebraic Geometry - Affine Algebraic Sets
In summary, Dummit and Foote, Exercise 20, Section 15.1 asks us to prove that if two irreducible polynomials in k[x,y] are not associates, their zero set in \mathbb{A}^2 is either empty or finite. To approach this problem, we can consider the contrapositive statement and show that if the zero set is infinite, the polynomials must have a common factor, leading to a contradiction. Therefore, the zero set must be either empty or finite.
Math Amateur
MHB
3,998
48
Dummit and Foote, Exercise 20, Section 15.1 reads as follows:
If f and g are irreducible polynomials in \(\displaystyle k[x,y] \) that are not associates (do not divide each other), show that \(\displaystyle \mathcal{Z} (f,g) \) is either the empty set or a finite set in \(\displaystyle \mathbb{A}^2 \).
I am somewhat overwhelmed by this problem and do not get much insight from D&F's hints on this exercise.
I would therefore appreciate someone heling me with an approach to this problem.
Peter
Hello Peter,
I understand your frustration with this problem. It can be quite challenging to approach at first glance. However, there are a few key concepts that can help guide your approach.
First, let's define some terms to make sure we are on the same page. An irreducible polynomial is one that cannot be factored into two non-constant polynomials. Associates in this context refer to polynomials that differ only by a unit factor, such as 2x and 4x. In other words, they are essentially the same polynomial.
Now, let's think about what the statement is asking us to prove. We have two polynomials, f and g, that are not associates. This means they cannot divide each other. We are looking at the set of points in the plane (represented by \mathbb{A}^2) where both f and g are equal to 0, also known as the zero set. The question is asking us to show that this set is either empty or finite.
To approach this problem, we can consider the contrapositive statement. This means we can assume that the zero set is infinite and try to derive a contradiction. We know that if the zero set is infinite, there must be an infinite number of points where both f and g are equal to 0. This means that there must be an infinite number of solutions to the system of equations f(x,y) = 0 and g(x,y) = 0.
Now, let's think about what this means for the polynomials f and g. If there are an infinite number of solutions to this system of equations, it means that f and g must have a common factor. This is because every solution to the system of equations must satisfy both f(x,y) = 0 and g(x,y) = 0, which means the solution must satisfy their common factor as well.
However, we know that f and g are not associates, so they cannot have a common factor. This leads to a contradiction, which means our assumption that the zero set is infinite must be false. Therefore, the zero set must be either empty or finite.
I hope this helps guide your approach to this problem. Let me know if you have any further questions or need clarification on any of the concepts. Good luck!
FAQ: Algebraic Geometry - Affine Algebraic Sets
What is an affine algebraic set?
An affine algebraic set is a subset of n-dimensional space that is defined by a set of polynomial equations. It can be thought of as the solution set to a system of polynomial equations.
What is the difference between an affine algebraic set and an algebraic variety?
An affine algebraic set is a subset of n-dimensional space, while an algebraic variety is a more general concept that includes not only subsets of n-dimensional space, but also subsets of other types of spaces, such as projective space. Additionally, an algebraic variety can be defined by both polynomial equations and polynomial inequalities.
How can affine algebraic sets be visualized?
Affine algebraic sets can be visualized by plotting the equations defining the set in n-dimensional space. For example, a 2-dimensional affine algebraic set can be plotted in 3-dimensional space by plotting the two equations as two surfaces and finding their intersection.
What is the importance of affine algebraic sets in algebraic geometry?
Affine algebraic sets play a crucial role in algebraic geometry as they provide a way to study and understand the solutions to systems of polynomial equations. They also allow for the creation of algebraic varieties, which are important objects in algebraic geometry.
How are affine algebraic sets related to commutative algebra?
Affine algebraic sets and commutative algebra are closely related as commutative algebra provides the tools and techniques for manipulating and solving systems of polynomial equations. Additionally, the notion of a coordinate ring, which is central in commutative algebra, is closely tied to the concept of an affine algebraic set.
