Algebraic Geometry Basics for Understanding Tensegrity in Masters Thesis
  • MHB
  • Thread starter caffeinemachine
  • Tags
    Geometry
In summary, algebraic geometry is a branch of mathematics that studies geometric objects defined by algebraic equations. It involves techniques such as polynomial equations, curves, surfaces, and higher-dimensional spaces, and is used to analyze the relationships between these objects. Understanding the basics of algebraic geometry can help in comprehending the concept of tensegrity, which is a structural system that uses a combination of compression and tension to create stable structures. This can be helpful in the context of a Masters Thesis that explores the use of tensegrity in various applications.
caffeinemachine
MHB
816
Hello MHB.
My masters thesis is on the subject of tensegreties (Most likely you don't know what that means.) Their study requires familiarity with Algebraic Geometry. I have no background in AG.
I need to understand this paper:
https://docs.google.com/file/d/0B77QF0wgZJZ7d2g2S3g1RVlQOE0/edit
Proposition 3.2 in the paper uses concept of an 'algebraic set', 'path selection results from AG' and 'curve selection result due to Milnor'.
At this point I have no idea what these are.
I have good understanding of UG algebra (esp groups and fields & Galois theory), Analysis and Point-set Topology.
Can somebody tell me what book(s) and topics I should cover so that I'd be in a position to understand the the paper at least partially?
I am allowed to do 3 months of reading bookish material and then go to reading papers.
caffeinemachine said:
Hello MHB.
I know very little algebraic geometry, but if I had to study that paper on tensegrity frameworks, I would start by looking at its Reference 10: Singular points of complex hypersurfaces, by John Milnor. You can get an idea of the style of Milnor's monograph by looking at the Google Books extracts here. Milnor seems to start in a fairly gentle way, by defining an algebraic set. The proof of his curve selection lemma comes quite early in the monograph, so you probably would not need to read the whole thing.
If you find Milnor tough going, you need to go back further, to a gentle introduction to the basics of algebraic geometry. I recommend Miles Reid: Undergraduate algebraic geometry.
Thank you Opalg for this detailed post.
Umm.. I don't think Milnor defines an Algebraic Set in that monograph.
Would you suggest reading commutative ring theory separately? I may be able to cover decent material from Martin Isaac's Algebra: A Graduate Course Algebra (Graduate Studies in Mathematics): I. Martin Isaacs: 9780821847992: Amazon.com: Books
Umm.. it's the first definition in the monograph!
No, I doubt whether that would be very much help. My impression is that, for the application you are interested in, you do not need a "modern", commutative-algebra-based version of algebraic geometry, but a more traditional, geometric approach that emphasises curves and surfaces. That is why I think that Miles Reid's book would be a good starting point.​
https://www.physicsforums.com/attachments/1252
Ummsorry. I saw the first line in section 1 where the author uses the name algebraic set without defining it. That's why I thought it's not defined in it. :eek:
Hello. Me again.
I have been reading the monograph by Milnor and Reid's book's chapter 2 seems to make things easy for me.
But I am having problems with things like 'smooth manifolds' and 'dimension of a manifold'. I know basic point set topology (as given in Part 1 of Simmon's Introduction to Topology and Modern Analysis) and I am comfortable with compactness, connectedness, Hausdorffness etc. But in Simmon's book manifolds weren't discussed at all. So that's why I need to read about them separately if I am to understand the curve selection lemma given in Milnor's monograph.
Can you suggest a good source for this. I wouldn't want to read something equivalent to a full course in these things since I don't have that much time. So please make suggestions keeping that in mind.
Thanks.
If you just need definitions and basic properties then you can find these online. Wikipedia is probably as good as anything. Start on the manifolds page, and follow references from there.
Okay.. I'll give it a shot. Thanks. My problem is I myself don't know how much I need to know about manifolds in order to understand the curve selection lemma. But anyway, I wouldn't know without trying I guess.
FAQ: Algebraic Geometry Basics for Understanding Tensegrity in Masters Thesis
What is Algebraic Geometry?
Algebraic Geometry is a branch of mathematics that studies the solutions to polynomial equations using algebraic techniques. It combines algebra and geometry to understand geometric objects defined by polynomial equations.
What are the applications of Algebraic Geometry?
Algebraic Geometry has many applications in fields such as physics, computer science, cryptography, and economics. It is used to solve optimization problems, model biological systems, and study geometric structures in higher dimensions.
What are the basic concepts in Algebraic Geometry?
The basic concepts in Algebraic Geometry include varieties, ideals, morphisms, and sheaves. Varieties are geometric objects defined by polynomial equations, ideals are sets of polynomials that vanish at certain points, morphisms are maps between varieties, and sheaves are mathematical objects that encode local information about a variety.
What are the differences between Algebraic Geometry and Differential Geometry?
Algebraic Geometry and Differential Geometry are both branches of geometry, but they use different tools to study geometric objects. Algebraic Geometry focuses on solutions to polynomial equations and uses algebraic techniques, while Differential Geometry studies smooth manifolds and uses differential calculus and topology.
How can I get help with Algebraic Geometry?
There are many resources available for getting help with Algebraic Geometry, including textbooks, online courses, and math forums. You can also seek help from a math tutor or join a study group. Additionally, many universities have math departments that offer tutoring services for students.
