Algebraic Inversion of Stress-Strain Relations?
In summary, algebraic inversion of stress-strain relations is a mathematical technique used to determine the stress and strain values of a material based on experimental data. It involves solving a set of equations to obtain the unknown parameters, such as the Young's modulus and yield strength, that characterize the material's behavior under stress. This approach is often used in the field of material science and engineering to analyze and predict the mechanical properties of materials.
Hypatio
151
How is this accomplished? How can one derive equations for stress in terms of strain from equations of strain in terms of stress or vice versa?
Which particular relations are you thinking of?
I think that the stress-strain relations for linear elasticity are
[tex]\sigma_{ij}=\lambda \epsilon_{kk} +2\mu\epsilon_{ij}[/tex]
and
[tex]\epsilon_{ij}=\frac{1+v}{E}\sigma_{ij}-\frac{v}{E}\sigma_{kk}[/tex]
Inversion is briefly discussed in 'section' 3.2.8 here:
http://solidmechanics.org/text/Chapter3_2/Chapter3_2.htm
but I do not comprehend how exactly the inversion is performed
My actual goal is to invert the viscoelastic stress-strain relation here:
[tex]\dot{\sigma_{ij}}+\frac{\mu}{\eta}\sigma_{ij}=2\mu\dot{\epsilon_{ij}}+\delta_{ij}\left [ \lambda\dot{\epsilon_{kk}}-k\alpha_V \dot{T}+k\frac{\mu}{\eta}(\epsilon_{kk}-\alpha_V T) \right ][/tex]
which obviously has some additional terms. But I'm not sure how trivial this is.
The basic idea is to write the stress-strain equations as a 6x6 matrix equation
[tex]\varepsilon = D \sigma[/tex]
and then invert the matrix. The matrix inversion is easy for an isotropic solid.
For the thermal example in your link, you then write the complete equation in matrix form
[tex]\varepsilon = D \sigma + A \Delta t[/tex]
where A is a vector. Then
[tex]D^{-1} \varepsilon = \sigma + D^{-1} A \Delta t[/tex]
which is usually written as
[tex]C \varepsilon = \sigma + C A \Delta t[/tex]
so
[tex]\sigma = C \varepsilon - C A \Delta t[/tex]
And you can multiply out CA to get the equations in your link.
Thanks, although I'm not sure how to treat some of the other terms which appear here:
[tex]\sigma_{ij}=2\mu\epsilon_{ij}+\epsilon\lambda+\delta_{ij}\left [\epsilonk\int_0^t\frac{\mu}{\eta}dt-k\alpha_V T-k\int_0^t\alpha_V\dot{T}\frac{\mu}{\eta}dt-\int_0^t\sigma_{ij}\frac{\mu}{\eta}dt \right ][/tex]
Can all of the terms be introduced into the same matrix [tex]C=D^{-1}[/tex] as you have done with [tex]k\alpha_V T[/tex] or do they have to be described with a unique matrix? I'm specifically unsure about how to deal with the last term in which [tex]\sigma_{ij}[/tex] appears. How is this introduced into the matrix formula?
Thanks again.
FAQ: Algebraic Inversion of Stress-Strain Relations?
What is the purpose of algebraic inversion of stress-strain relations?
The purpose of algebraic inversion of stress-strain relations is to determine the material properties of a solid material based on its stress-strain behavior. This can be useful in engineering and material science applications, as it allows for the prediction of a material's behavior under different loading conditions.
How is algebraic inversion of stress-strain relations performed?
Algebraic inversion of stress-strain relations involves using mathematical techniques to manipulate the stress-strain equations in order to isolate and solve for the material properties, such as the Young's modulus and Poisson's ratio. This typically involves using a combination of algebra, calculus, and matrix operations.
What are some common challenges in algebraic inversion of stress-strain relations?
One common challenge in algebraic inversion of stress-strain relations is dealing with experimental data that may be noisy or have errors. This can lead to inaccurate results and require additional data processing or filtering techniques. Another challenge is selecting the appropriate stress-strain model to use, as different materials may exhibit different types of behavior.
What are the benefits of using algebraic inversion of stress-strain relations?
The main benefit of using algebraic inversion of stress-strain relations is that it allows for the determination of material properties without the need for destructive testing. This can save time and resources in materials testing and also provide a better understanding of a material's behavior. Additionally, the resulting material properties can be used in predictive models for design and analysis purposes.
Are there any limitations to algebraic inversion of stress-strain relations?
One limitation of algebraic inversion of stress-strain relations is that it assumes a linear relationship between stress and strain, which may not always be the case for certain materials. Additionally, the accuracy of the results depends on the quality and quantity of the experimental data used. In some cases, other techniques such as finite element analysis may be more suitable for determining material properties.
