MHB Algebraic Proofs and Verifying identities
  • Thread starter Thread starter abbarajum
    identities Proofs
The discussion revolves around proving the algebraic identity sin43x - cos43x = 1 - 2cos23x. The original poster initially attempted to manipulate the right-hand side but found it complex and confusing, leading to a dead end. Suggestions from other participants included using the difference of squares identity and substituting sin^2(3x) to simplify the expression, which helped clarify the approach. Ultimately, the poster realized that these strategies made the problem more manageable and expressed gratitude for the guidance received. The conversation highlights the importance of strategic substitutions and identities in solving algebraic proofs.
abbarajum
Hey all! I am having some trouble with a certain problem on my homework. I would like some guidance. I have to prove one side of the equation is equal to the other, as you may know, as this is an algebraic proof. This in itself isn't too hard. The hard part is just this one particular problem. I may be going about this the wrong way... but the problem seems really complex.
Statement to prove: sin43x - cos43x = 1 - 2cos23x
I first tried starting with the right hand side.
1 - 2cos23x = - (2cos23x - 1)
- (2cos23x - 1) = - cos2(3x)
I don't know if I am allowed to call that - cos6x, but I did. And I looked up the formula for cos6x, which is:
32cos6x - 48 cos4x + 18 cos2x - 1
Therefore, - cos6x = 1- 32cos6x + 48 cos4x - 18 cos2x
I even tried expanding cos3x first, then squaring it. I got the same exact terms, and wasn't really sure what to do with them:
1 - 2cos23x = 1 - 2 (4cos3x - 3cosx)2
1 - 2 (4cos3x - 3cosx)2 = 1 - 2 (16cos6x - 24cos4x + 9cos2x)
1 - 2 (16cos6x - 24cos4x + 9cos2x) = 1 - 32cos6x + 48cos4x - 18cos2x
So I got stuck there, and decided to go with the left hand side.
Starting with the LHS:
sin43x - cos43x = (3sinx - 4sin3x)4 - (4cos3 - 3cosx)4
So, I tried to use that formula for when you have (a - b)4, and here's what I ended up getting:
(81sin4x - 432sin6x + 864sin8x - 768sin10x + 256sin12x) - (256cos12x - 768cos10x + 864cos8x - 432cos6x +81cos4x)
Then, expanding further and rearranging (from smallest degrees to largest degrees):
81sin4x - 81cos4x - 432sin6x + 432cos6x + 864sin8x - 864cos8x - 768sin10x + 768cos10x + 256sin12x - 256cos12x
So I am pretty much stuck here. I mean, I see a pattern when I begin with the LHS, but I'm not sure if I am on the right track. Am I missing something, or am I overthinking? Am I way off? Or did I just make a little mistake? Or can I go further?
I will be happy to clarify something - this can be weird to type out.
Thanks!
Mathematics news on Phys.org
Thanks!
Hi abbarajum! Welcome to MHB! :)
I guess you can do it like that, but as you can see it becomes long and complex.
How about substituting:
$$\sin^2(3x) = 1 - \cos^2(3x)$$
Then you have $\cos(3x)$ everywhere and no other trig functions.
They should cancel then.
Thanks!
Hi abbarajum,
If you consider the difference of squares identity $a^2 - b^2 = (a - b)(a + b)$, you can write
$$\sin^4 3x - \cos^4 3x = (\sin^2 3x - \cos^2 3x)(\sin^2 3x + \cos^2 3x).$$
Use the Pythagorean identity $\sin^2 \theta + \cos^2 \theta = 1$ to simplify the RHS of the above equation to $1 - 2\cos^2 3x$.
Hi, I like Serena!
Thanks for your response.
Where would you substitute sin23x? Would you substitute it on the right hand side, so that:
1 - 2cos23x = 2sin23x
Thanks again.
(Sorry if this question seems a little silly.)
- - - Updated - - -
Euge said:
Hi abbarajum,
Hi, Euge.
Ugh, that makes it so much easier! Why didn't I think of that earlier?
Thanks so much! :)
abbarajum said:
Hi, I like Serena!
Thanks again.
I suggest doing it on the LHS:
$$\sin^4(3x) - \cos^4(3x) = (\sin^2(3x))^2 - \cos^4(3x)
= (1 - \cos^2(3x))^2 - \cos^4(3x)$$
Or you can do it as Euge suggested.
Okay, I got it now - way easier than I originally thought it to be.
Thanks for both of your responses. I really appreciate them.
Have a great day!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
