Algebraic Test For Symmetry....1
  • Thread starter nycmathguy
  • Tags
    Test
The resulting equation is identical to the original, so there is symmetry about the x-axis.You then try both substitutions simultaneously, and find that the resulting equation is not equivalent to the original, so there is no symmetry about the origin.In summary, the equation x - y^2 = 0 is not symmetric with respect to the y-axis, but is symmetric with respect to the x-axis. There is no symmetry about the origin.
nycmathguy
Use the algebraic tests to check for
symmetry with respect to both axes and the origin.
N/A
PUse the algebraic tests to check for
x - y^2 = 0
Let x = -x
-x - y^2 = 0
Not symmetric with respect to the y-axis.
Let y = -y
x - (-y)^2 = 0
x - y^2 = 0
Symmetric with respect to the x-axis.Let x = -x and y = -y
-x - (-y)^2 = 0
-x - y^2 = 0
Not symmetric with respect to the origin.
Likes Delta2
Say f(x,y)=0 given
Symmetry respect to y-axis is
[tex]f(-x,y)=0[/tex]
Symmetry with respect to x-axis is
[tex]f(x,-y)=0[/tex]
Symmetry with respect to Origin is
[tex]f(-x,-y)=0[/tex]
  • Love
Likes Delta2
anuttarasammyak said:
Say f(x,y)=0 given
Good to know but is my work correct?
If you are interested in post #2 for
nycmathguy said:
Homework Statement:: Use the algebraic tests to check for
Relevant Equations:: N/A
x - y^2 = 0
apply
[tex]f(x,y)=x-y^2[/tex]
and check it as another homework.
apply
How is f(x, y) applied to the equation?
nycmathguy said:
x - y^2 = 0
Let x = -x
-x - y^2 = 0
##f(x,y)=x-y^2=0##
##f(-x,y)=-x-y^2=-2x+f(x,y)=?##
##f(x,y)=x-y^2=0##
If f(x,y) = 0, then -2x + f(x,y) is -2x + 0 = -2x.
Likes Delta2
##f(x,y)=x-y^2=0##
I don't know what you're doing in the 2nd line above.
##f(-x, y) = -x - y^2 \ne f(x, y)##, so not symmetric about the y-axis.
Someone else got it wrong? Happy to know it's not me this time. Precalculus is way over our heads, right? Mark44, when I think about precalculus, abstract algebra aka modern algebra does not come to mind. Understand?
I am not intimidated by a course I took and passed with an A minus in 1993. I take it day by day. I can do without belittling comments from several members like THIS IS BABY MATH or YOU SHOULD ALREADY KNOW THIS STUFF, etc. Get it? Not very encouraging at all. Either provide help or skip my "easy" problems.
P. S. My upper case letters are for emphasis only. Sorry but I am not a millennial. I was raised in a society that was not "politically correct" as the new saying goes.
Abstract algebra/modern algebra is an advanced subject that you have never seen before. It should not be confused with algebra as taught in high school. Modern algebra deals with things like groups, rings, and other mathematical structures.
Likes symbolipoint
##f(x,y)=x-y^2=0##
##=-2x+0=-2x##
So ##f(-x,y)\neq 0##. f is not symmetric wrt y axis.
No, I just didn't understand what @anuttarasammyak was doing, which he clarified in a subsequent post.
##=-2x+0=-2x##
You missed my point. When I think about precalculus abstract algebra does not come to mind. By this I mean that precalculus is not so bad if guided correctly, calmly and patiently.
##=-2x+0=-2x##
Is my answer -2x wrong?
No, you missed my point. Abstract algebra is different from "ordinary" algebra as taught in high school. I gave a brief description of some of the topics that are included in abstract algebra AKA modern algebra.
It's incomplete in the context of this problem, which is to determine whether the function ##f(x, y) = x - y^2 = 0## is symmetric about the y-axis. What do you conclude when you determine that ##f(-x, y) = -x - y^2 = -2x + 0##?
You know, Mark44, I am not going to bother arguing about this again and again. Precalculus is easier than abstract algebra. This is my point. The answer to your question is: IDK. Good night.
Yes, which is why abstract algebra is often taught as a 400-level course in two semesters in the senior year of a mathematics undergrad degree.
Thank God I never have to face that course. My goal: To learn precalculus through calculus 3. I may try linear algebra after calculus 3 but not sure at this time. I still have a long way to go.
x - y^2 = 0
Let x = -x
-x - y^2 = 0
Let y = -y
x - (-y)^2 = 0
x - y^2 = 0
-x - (-y)^2 = 0
-x - y^2 = 0
As I understand your approach to the problem...
You have an equation in x and y. You substitute -x for x in this equation and test whether the result is an equivalent equation. You judge that it is not. So you conclude that there is no symmetry about the y axis.
Correct conclusion.
You repeat, substituting -y for y and test whether the result is an equivalent equation. After simplifying, you see that the resulting equation is indeed identical. So you conclude that there is symmetry about the x axis.
Correct conclusion.
You repeat again, performing both substitutions this time. Again you test whether the resulting equation is equivalent to the original. You judge that it is not.
Correct conclusion.However, the approach that you have selected has at least two potential pitfalls.
1. It depends on your being able to correctly recognize when two equations are or are not equivalent.
In this case your judgement was sound.
2. Strictly speaking, symmetry does not require that the substituted equation be formally equivalent to the original. It is enough that the solution sets are identical.
Say, for instance, we have the equation x2 + 2x + 100 = -y2 and that we are testing for symmetry about the y axis. We replace x and -x and see that the new equation: x2 - 2x + 100 = -y2 is not equivalent. We [falsely] conclude that there is no symmetry.
But the solution set to both equations is empty. So the graphs of the solution sets are both empty and, therefore, identical. So there is symmetry.
Likes nycmathguy
Correct conclusion.
Correct conclusion.
Interesting reply. I thank you.
It's true that the equation in your example has symmetry, but the kinds of symmetry in the multiple problems posted here so far are specifically limited to symmetry about the x- or y-axis or the origin. The equation you showed is symmetric about the x-axis and about the line x = -1, but not about the y-axis.
On the contrary. It is symmetric about the y-axis as well. The graph is not a parabola. It is empty.
However, you may be working one step beyond me, speaking of a formal symmetry of the equation rather than a graphical symmetry of the solution set. If one extended the domain of x and y to include the complex numbers for instance, then the graphical symmetry would vanish and the formal symmetries (if any) would remain.
I didn't say it was a parabola, but I mistakenly thought it was a circle.
If we write ##f(x, y) = 0 = x^2 + 2x + y^2 + 100##, then ##f(x, -y) = 0##, so the equation is symmetric about the x-axis (whatever that means for an equation with an empty graph), but ##f(-x, y) \ne f(x, y)##, so the equation is not symmetric about the y-axis.
In any case, your example would not be a good choice for a problem in the first chapter of a precalculus textbook.
Likes jbriggs444
Ahh, yes. A funny sort of circle with a negative radius. I hadn't visualized it that way. Quite apt.
Interesting reading. Thank you everyone.
FAQ: Algebraic Test For Symmetry....1
What is an algebraic test for symmetry?
An algebraic test for symmetry is a method used to determine if a graph or equation is symmetrical. It involves substituting negative values for the independent variable in the equation and checking if the resulting points are symmetrical to the positive values.
How is the algebraic test for symmetry different from the graphical test?
The algebraic test for symmetry involves substituting values into an equation, while the graphical test involves visually inspecting the graph for symmetry. The algebraic test is often considered more accurate as it can be applied to any equation, while the graphical test may be limited by the scale or precision of the graph.
What are the conditions for a graph to pass the algebraic test for symmetry?
For a graph to pass the algebraic test for symmetry, the equation must remain unchanged when the independent variable is replaced with its negative value. This means that the graph must be symmetrical with respect to the y-axis.
Can the algebraic test for symmetry be applied to all types of equations?
Yes, the algebraic test for symmetry can be applied to all types of equations, including linear, quadratic, exponential, and trigonometric equations. However, the method of substitution may vary depending on the type of equation.
Is the algebraic test for symmetry a reliable method?
Yes, the algebraic test for symmetry is a reliable method as it provides a mathematical proof of symmetry. However, it is important to note that this test only determines if a graph or equation is symmetrical, it does not provide information about the type of symmetry (e.g. rotational, reflectional).
