MHB Algorithm for Ordering Odds & Evens in Linked List L
  • Thread starter Thread starter evinda
    Algorithm List
The discussion centers around creating an algorithm to rearrange a singly-linked list, where elements with odd numbers appear before those with even numbers, while maintaining their original order. The initial attempt at the algorithm is critiqued for referencing null pointers and for traversing the list twice—once for odd numbers and once for even numbers. A complete solution is provided, which correctly implements the idea of appending odd and even nodes to a new list. The solution includes a function that constructs the linked list and another that rearranges it. However, it is suggested that the exercise likely intended for a single traversal of the list to achieve the desired outcome, which would be a more efficient approach. The discussion concludes with a query about whether the provided function only appends odd nodes, indicating a need for clarification on the complete functionality of the rearrangement process.
evinda
MHB
Hello! (Wave)
Consider a singly-linked list [m] L[/m] each element of which is a struct with two fields, an integer [m]num[/m] and a pointer [m]next[/m] to the next element of the list.
Describe an algorithm that gets as argument a pointer to the first element of the list [m]L[/m] and that creates a new list [m]L'[/m] that will contain all the elements of [m]L[/m] ordered in the following way:
The elements of [m]L[/m] for which the field [m]num[/m] is an odd number have to appear in [m]L'[/m] before all the elements of which the field [m]num[/m] is an even number. The elements with an odd number at the field [m]num[/m] should keep in [m]L'[/m] the display order that they had at the initial list [m]L[/m].
The same should hold for the elements with an even number at the field [m]num[/m].
For example, if the initial list is [m]L=13->15->20->17->24->26->9->30->53->44[/m] the final list should be [m]L'=13->15->17->9->53->20->24->26->50->44[/m].That's what I have tried:
Code:
   List(L){
      if (L==NULL) return;
      node *p=NULL, *q=L, *l=L, *L3=NULL, *head2=NULL, *tail1=NULL, *tail2=NULL;
      while (q!=NULL){
            if (q-> num mod 2==1){
                if (p==NULL){
                   p->num=q->num;
                   L3=p;
                else {
                   p=p->next;
                   p->num=q->num;
      tail=p;
      while (l!=NULL){
            if (l-> num mod 2==0){
               if (l==NULL){
                   l->num=q->num;
                   head2=l;
                else {
                   l=l->next;
                   l->num=q->num;
      tail2=q;
      tail1->next=head2;
      tail1=tail2;
      return L3;
Could you tell me if it is right?
Technology news on Phys.org
Evinda,
No, it's not right. You continue to make the error of referencing a field of a null pointer. However, your main idea is okay. You traverse the list L twice with the first traversal appending all "odd" nodes to an initially empty list L3, and the second traversal appending the "even" nodes to L3. So your first while loop is pretty much correct. I could make no sense of the second while loop.
Here's a complete solution using your idea:
Code:
class Node {
public:
  int num;
  Node* next;
  Node(int v) : num(v), next(0) {
Node* makeList(int a[], int n) {
  if (n == 0) {
    return (NULL);
  int i;
  Node* first = new Node(a[0]), *p = first;
  for (i = 1; i < n; i++) {
    p->next = new Node(a[i]);
    p = p->next;
  return (first);
Node* rearrange(Node* L) {
  Node* L3 = NULL, *p, *q;
  if (L == NULL) {
    return (NULL);
  int i;
  for (i = 1; i >=0; i--) {
    q = L;
    while (q != NULL) {
      if (q->num % 2 == i) {
        if (L3 == NULL) {
          L3 = new Node(q->num);
          p = L3;
        } else {
          p->next = new Node(q->num);
          p = p->next;
      q = q->next;
  return(L3);
int main(int argc, char** argv) {
  int a[] = {13, 15, 20, 17, 24, 26, 9, 30, 53, 44};
  Node *L = makeList(a, 10), *p = L;
  while (p != NULL) {
    cout << p->num << " ";
    p = p->next;
  cout << endl;
  Node* Lprime = rearrange(L);
  p = Lprime;
  while (p != NULL) {
    p = p->next;
  cout << endl;
  return (0);
However, I strongly suspect the exercise meant for you to write a function that traverses the original list only once. This is only slightly more complicated. I advise you to write this function.
johng said:
Evinda,
Code:
class Node {
public:
  int num;
  Node* next;
  if (n == 0) {
    return (NULL);
  int i;
    p = p->next;
  return (first);
  if (L == NULL) {
    return (NULL);
  int i;
    q = L;
    while (q != NULL) {
        if (L3 == NULL) {
          p = L3;
        } else {
          p = p->next;
      q = q->next;
  return(L3);
  while (p != NULL) {
    p = p->next;
  cout << endl;
  p = Lprime;
  while (p != NULL) {
    p = p->next;
  cout << endl;
  return (0);
With the function [m] rearrange [/m] we only append all "odd" nodes to the list L3, right?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
