Algorithm Optimization [Python]
In summary, the first two values in order of appearance that add up to form the sum are 3 + 7 and 4 + 2.
Jamison Lahman
143
35
Given a list of integers and a single sum value, return the first two values (parse from the left please) in order of appearance that add up to form the sum.
Python:
sum_pairs([11, 3, 7, 5],         10)
#              ^--^      3 + 7 = 10
== [3, 7]
sum_pairs([4, 3, 2, 3, 4],         6)
#          ^-----^         4 + 2 = 6, indices: 0, 2 *
#             ^-----^      3 + 3 = 6, indices: 1, 3
#                ^-----^   2 + 4 = 6, indices: 2, 4
#  * entire pair is earlier, and therefore is the correct answer
== [4, 2]
sum_pairs([0, 0, -2, 3], 2)
#  there are no pairs of values that can be added to produce 2.
== None/nil/undefined (Based on the language)
sum_pairs([10, 5, 2, 3, 7, 5],         10)
#              ^-----------^   5 + 5 = 10, indices: 1, 5
#                    ^--^      3 + 7 = 10, indices: 3, 4 *
== [3, 7]
Negative numbers and duplicate numbers can and will appear.
NOTE: There will also be lists tested of lengths upwards of 10,000,000 elements. Be sure your code doesn't time out.This is a problem off of codewars.com. I have made two versions that satisfy the eight examples but there is a 12000ms time restraint that I need to overcome. I am not versed in CS so I don't know much about algorithms or how to optimize them.
2. Homework Equations
The examples are:
Python:
l1= [1, 4, 8, 7, 3, 15]
l2= [1, -2, 3, 0, -6, 1]
l3= [20, -13, 40]
l4= [1, 2, 3, 4, 1, 0]
l5= [10, 5, 2, 3, 7, 5]
l6= [4, -2, 3, 3, 4]
l7= [0, 2, 0]
l8= [5, 9, 13, -3]
print(sum_pairs(l1, 8) == [1, 7]) #"Basic: %s should return [1, 7] for sum = 8" % l1)
print(sum_pairs(l2, -6) == [0, -6]) #"Negatives: %s should return [0, -6] for sum = -6" % l2)
print(sum_pairs(l3, -7) == None) #"No Match: %s should return None for sum = -7" % l3)
print(sum_pairs(l4, 2) == [1, 1]) #"First Match From Left: %s should return [1, 1] for sum = 2 " % l4)
print(sum_pairs(l5, 10) == [3, 7]) #"First Match From Left REDUX!: %s should return [3, 7] for sum = 10 " % l5)
print(sum_pairs(l6, 8) == [4, 4]) #"Duplicates: %s should return [4, 4] for sum = 8" % l6)
print(sum_pairs(l7, 0) == [0, 0]) #"Zeroes: %s should return [0, 0] for sum = 0" % l7)
print(sum_pairs(l8, 10) == [13, -3]) #"Subtraction: %s should return [13, -3] for sum = 10" % l8)
They should all return True
My first attempt is simple and straight forward:
Python:
def sum_pairs(ints, s):
    prev_list = []
    for num in ints:
        for test in prev_list:
            if num+test == s:
                return ([test, num])
        prev_list += [num]
My second attempt is the same structure however I store and organize previous test numbers by either positive or negative:
Python:
    neg_list = []
    pos_list = []
    for num in ints:
        if num > s:
            for neg in neg_list:
                if neg == s - num:
                    return [neg,num]
        else:
            for pos in pos_list:
                if pos == s - num:
                    return [pos,num]
        if num < 0:
            neg_list += [num]
        else:
            pos_list += [num]
With this new method, I went from 50 total possible returns to 31. I am not sure if this is the right direction to go. It very well may be I'm doing more work by organizing than I am saving.
From here, my plan was to make four lists: two negatives with one where abs(number) >= abs(s) and the other abs(number) < abs(s) with a similar pattern for positive numbers. I think it might be helpful to find the sign of 's' at the very beginning but I haven't figured out how to use that to my advantage..
Technology news on Phys.org
You just need to look at all the numbers once, and store them is such a way while doing this, you can immediately look up if the new number forms a pair with any number that you have already seen.
This can be done in a lot of ways: keeping the list sorted, storing the list as a hashtable or tree, or use an array of all the possible values that can occur.
Ahhh I think I was trying to do this intuitively but lacked the programming experience. I think I will try to sort the list first:
Code:
if prev_num not in prev_list:
    prev_list += [prev_num]
    prev_list = sorted(prev_list)
After that, I will be able search the list backwards or forwards until (s-(num+test)) changes signs.
If that doesn't do the trick, I will try hashtables. The book I used to learn python briefly mentioned how fast hashtables were but didn't go over them in-depth.
Thanks
Related to Algorithm Optimization [Python]
1. What is algorithm optimization in Python?
Algorithm optimization in Python involves improving the efficiency and performance of a given algorithm. This can include modifying the code, data structures, or algorithms used to achieve better speed, accuracy, and memory usage.
2. Why is algorithm optimization important?
Algorithm optimization is important because it allows for faster and more accurate execution of algorithms, which is crucial in various fields such as data science, machine learning, and artificial intelligence. It also helps reduce computing costs and improves user experience.
3. How can I optimize my algorithms in Python?
There are several ways to optimize algorithms in Python, including using efficient data structures, reducing unnecessary computations, and implementing parallel processing. Utilizing built-in functions and libraries, such as NumPy and Pandas, can also significantly improve algorithm performance.
4. What are some common challenges in algorithm optimization?
Some common challenges in algorithm optimization include balancing trade-offs between speed and accuracy, dealing with large datasets, and selecting the most suitable data structures and algorithms for a given problem. It can also be challenging to optimize complex algorithms with multiple parameters.
5. How do I measure the performance of optimized algorithms?
The performance of optimized algorithms can be measured using metrics such as execution time, accuracy, and memory usage. It is also essential to compare the performance of the optimized algorithm with the original algorithm to determine the effectiveness of the optimization techniques used.
