MHB Algorithm with time complexity o(n^2)
The discussion centers on developing an efficient algorithm to find two elements in a set of real numbers that have the minimum absolute difference, with a time complexity of less than O(n^2). The proposed solution involves first sorting the set using heapsort, which has a time complexity of O(n log n), followed by a single pass through the sorted list to find the minimum difference between consecutive elements. This approach effectively reduces the overall complexity to O(n log n), which meets the requirement of being less than O(n^2). The participants also discuss the correctness of the algorithm, suggesting that induction could be used to prove its validity. The focus remains on optimizing the algorithm while ensuring its correctness.
evinda
MHB
Hi! (Smile)
I am looking at the following exercise:
Let $M=\{ y_1, y_2, \dots, y_n \}$ a set of real numbers, where $n \geq 2$. Describe an algorithm, that has time complexity $o(n^2)$ and that finds and returns two elements $y_k$ and $y_l$ of $M$, such that:
$$|y_k-y_l|=\min_{1 \leq i,j \leq n} |y_i-y_j|$$I think that we cannot do this with the use of two while loops, because the time complexity will be $\leq cn^2$, but we want it to be $<cn^2$, or am I wrong? (Thinking)
How else could we do this? (Worried)
Technology news on Phys.org
First sort the values (with say heap sort) of time complexity $n\ln\,n$. Then in the sorted list find the desired elements in one pass of the n elements. Total complexity "little oh" $n^2$.
So, is it right like that? (Thinking)
Code:
Heapsort(A){
  Buildheap(A);
  for (i=size(A); i>1; --i){
       swap(A[i],A[1]);
       heap_size(A)=heap_size(A)-1;
       Heapify(A,1);
Elements(S,n){
  int i,min,k;
  Heapsort(S)
  min=abs(S[1]-S[2]);
  for (i=2; i<n; i++){
      if (abs(S[i]-S[i+1])<min)
          min=abs(S[i]-S[i+1]);
          k=i;
  return S[k],S[k+1];
Looks right to me.
How could we show the correctness of the algorithm?
Could we prove that it is correct, using induction on [m] i [/m] ?
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
