Alkaline Alternative to Laundry Detergent?
  • Thread starter Naty1
In summary, the Super Wash Balls are designed to clean your laundry as effectively as detergent for up to 1100 loads. Made with all-natural, chemical-free bioceramics, they're designed to change the alkalinity of the water into basic water through oxidation reduction. Basic water has much smaller molecules that can easily penetrate through your fabrics and wash off any dirt for fresh, clean clothes load after load.
Naty1
5,606
40
Super Wash Ball Set of 2 Laundry Cleaners with 1100 Washes
A link below to a product I haven't seen before...
I have no connection with this product whatsoever but am considering trying it.
From the link below:
Ditch the detergent... Super Wash Balls are designed to clean your laundry as effectively as detergent for up to 1100 loads. Made with all-natural, chemical-free bioceramics, they're designed to change the alkalinity of the water into basic water through oxidation reduction. Basic water has much smaller molecules that can easily penetrate through your fabrics and wash off any dirt for fresh, clean clothes load after load.
I would appreciate comments from a chemical/environmental perspective. Seems from reviews from customers at QVC they do work. Clothing stains apparently must be pretreated with a stain remover. The ceramic balls must be put outside to dry periodically and eliminate any odors. Otherwise, no detergent required!
http://www.qvc.com/Super-Wash-Ball-Set-of-2-Laundry-Cleaners-with-1100-Washes-Search-Results.product.V32119.html?sc=V32119-SRCH&cm_sp=VIEWPOSITION-_-1-_-V32119&catentryImage=http://images-p.qvc.com/is/image/v/19/v32119.001?$uslarge$#divProductDetailsCustomerReviewWrapper
My comments:
From the reviews, saves money, always nice.
Maybe reduce phosphate run off into waste water and oceans?
Does basic [alkaline] water produced help to balance acid rain??
Any effect of basic water on clothing longevity...natural versus man made fibers [say cotton, nylon for example]...on wrinkles...??
Wonder if the 'ceramic' makes noise in washers..especially front loaders.
Can this eliminate the musty smell in some front loaders [like mine] eliminating the need to 'wash the washer' once a month or so with a special cleaner.
Soap has some effects on bacterial growth...How does alkaline water compare??
Chemistry news on Phys.org
My wife watched the televised discussion/promotion of the product...they said hydrogen peroxide is produced??
Chemical free? So what are they done from, quark-gluon plasma? Neutrinos?
Word salad.
Cattle male poo.
Or Male Cattle Poo.
Some areas where the water is 'hard' (it contains a lot of dissolved minerals) require the use of special detergents.
If you use salt water for washing or showering aboard ship, you need special salt water soap.
I wasn't sure whether "male cattle" or "cattle male" is correct. English is my second language, now and then it shows. But you know what I meant.
For English, the order is Adjective Noun for prose. In poetry, sometimes this order is reversed.
Thanks. My problem was with realizing male is an adjective here, and not a noun.
We have been using the 'wash ball set' for about ten days now...so far so good. They seem to work just fine...If my wife is happy I am happy! Unfortunately she threw out the box the cleaner comes in, so I never got a chance to see what ingredients might have been listed. Turns out the 'set' are used two at a time for every wash, sort of a 'part A and part B', some sort of chemcial activity occurs when they are wetted together. Turns out the porous ball containers are a soft plastic, no noise during wash that we can hear.
Our front load clothes washer is a model that gets a moldy smell when used with detergents and so has to be run with a cleaner [and no clothes] to eliminate odors about once a month. So far, that odor has been eliminated which is one thing I was hoping for. The laundry room used to get a musty odor toward the end of the monthly cleaning cycle, no more!
So while the promotional descriptions stink, our laundry is clean and fresh.
Related to Alkaline Alternative to Laundry Detergent?
1. What is an alkaline alternative to laundry detergent?
An alkaline alternative to laundry detergent is a cleaning solution that has a pH level above 7, making it more basic than traditional laundry detergents. These alternatives are often made from natural ingredients and are free from harsh chemicals.
2. How does an alkaline alternative to laundry detergent work?
Alkaline alternatives work by breaking down dirt and stains through a process called saponification. This reaction occurs when the alkaline solution comes into contact with oils and fats, creating a soap-like substance that can be easily rinsed away.
3. Is an alkaline alternative to laundry detergent safe for all types of fabric?
Yes, most alkaline alternatives are safe for all types of fabric. However, it is always best to test a small, inconspicuous area of the fabric first to ensure it does not cause any damage or discoloration.
4. Can an alkaline alternative to laundry detergent replace traditional detergent completely?
It depends on personal preference and the specific brand of alternative being used. Some people may find that the alkaline alternative is just as effective at cleaning their clothes, while others may prefer to use a combination of both traditional detergent and the alternative.
5. Are there any environmental benefits to using an alkaline alternative to laundry detergent?
Yes, there are several environmental benefits to using an alkaline alternative. These alternatives often use natural and biodegradable ingredients, reducing the amount of harsh chemicals being released into the environment. They also typically come in recyclable or reusable packaging, reducing waste.
