Alkalis and bases differentiation
In summary, the conversation discusses the topic of bases and alkalis. It is mentioned that an alkali is a soluble base, and the question arises whether Sodium Oxide and Lithium Hydroxide, both in solid form, are considered alkalis. It is concluded that they would still be considered alkalis when dissolved, as the resulting solution would have a pH higher than 7 due to the presence of OH- ions from the hydroxide.
Udhaya
Hi, I have a doubt on the topic of bases and alkalis. I have learned that a alkali is a soluble base so does that mean Sodium Oxide(Solid) is a alkali and Lithium Hydroxide(Solid) is a alkali. Or are they considered alkali when they are dissolved? For example, Sodium Oxide becomes sodium hydroxide which is alkali in aqueous form.
Chemistry news on Phys.org
I believe that they would still be considered as alkali when dissolved as it would result in a solution that had a pH higher than 7, it would be that OH- ions that would cause the alkaline pH which are from that hydroxide in this case.
Related to Alkalis and bases differentiation
1. What is the difference between an alkali and a base?
Alkalis and bases are often used interchangeably, but technically, they have different definitions. An alkali is a specific type of base that dissolves in water to form hydroxide ions (OH-), while a base is a substance that can neutralize an acid.
2. How can you tell if a substance is an alkali or a base?
To determine if a substance is an alkali or a base, you can perform a simple pH test. Alkalis have a pH greater than 7 and turn red litmus paper blue, while bases have a pH of 7 and do not cause a change in litmus paper.
3. Are alkalis and bases always caustic or corrosive?
No, not all alkalis and bases are caustic or corrosive. While some strong alkalis and bases can be harmful to living organisms and cause damage to certain materials, many weak alkalis and bases are actually safe to handle and use.
4. Can alkalis and bases be found in nature?
Yes, alkalis and bases can be found in nature. For example, sodium hydroxide (an alkali) can be found in certain types of rocks and minerals, and ammonia (a base) is naturally produced by living organisms such as plants and animals.
5. How are alkalis and bases used in everyday life?
Alkalis and bases have numerous everyday uses, including cleaning products, food production, and medicine. For example, sodium hydroxide is used in soaps and detergents, and ammonia is used in fertilizers and household cleaners. Bases are also used in antacids to help neutralize stomach acid.
