Alkylation of Imines: achiral to chiral compounds
In summary, the conversation discusses a method for converting achiral 2-pentanone to a chiral compound using HCl in pentane. This method involves an addition reaction and a two-step process, which is described as the alkylation of imines using iPr2NLi (LDA). The use of pentane with HCl is to create a biphasic system for the hydrolysis of the imine, with the ketone product being preferentially soluble in pentane. The role of iPr2NLi is to abstract a proton from the starting imine, creating a nucleophile that can undergo a nucleophilic substitution reaction with an alkyl iodide.
AdityaDev
527
33
I found this in "March's Advanced organic chemistry"
After that step, on using HCl in pentane, you will get 4-methyl-3-Heptanone.
So this method was used to convert achiral 2-pentanone to a chiral compound, by first converting it to the compound on left by addition reaction and then using a 2 step process. On checking the appendix, its given that the reaction is alkylation of imines.
Can someone give me the mechanism for alkylation of imines using iPr2NLi?
And what's the use of pentane with HCl?
Chemistry news on Phys.org
iPr2NLi (also known as LDA) is a strong base, so start by figuring out what protons on the starting imine are going to be the most acidic. Maybe look up "enamines" to get an idea of why they're nucleophilic. Once you abstract a proton with LDA, you'll be left with a nucleophile which can attack the alkyl iodide in a standard nucleophilic substitution reaction.
As for the pentane/HCl combo, there are a few different reasons why you'd want to use a biphasic system for the hydrolysis of the imine. My guess is that the ketone final product is preferentially soluble in pentane and the imine is preferentially soluble in water (aqueous HCl). Since imine hydrolysis is an equilibrium reaction, as the ketone is generated, it is pulled into the pentane solution, shifting the reaction further toward the ketone product.
Likes AdityaDev
I know about LDA. It's also used in aldol condensation to produce thermodynamic enolate.
It usually extracts proton from carbon right next to ketone group. Here it takes proton from aliphatic secondary carbon next to C=N group.
Related to Alkylation of Imines: achiral to chiral compounds
1. What is alkylation of imines?
Alkylation of imines is a chemical reaction in which an alkyl group is added to an imine compound. This results in the formation of a new chiral compound, as the alkyl group introduces a new asymmetric center.
2. Why is alkylation of imines important in organic synthesis?
Alkylation of imines is an important method for the synthesis of chiral compounds, as it allows for the creation of new stereocenters. These compounds can then be used in various applications, such as pharmaceuticals or materials.
3. How does alkylation of imines differ from other methods of creating chiral compounds?
Unlike other methods, such as asymmetric catalysis or enzymatic reactions, alkylation of imines does not require the use of a chiral catalyst or enzyme. Instead, the chirality is introduced through the addition of an achiral alkyl group.
4. What are the key factors to consider in alkylation of imines?
The key factors to consider in alkylation of imines include the choice of imine and alkylating agent, the reaction conditions, and the purification methods. These factors can greatly affect the yield and stereochemistry of the final product.
5. Can alkylation of imines be used for the synthesis of complex chiral compounds?
Yes, alkylation of imines can be used for the synthesis of complex chiral compounds, as it allows for the creation of multiple stereocenters in a single step. However, it is important to carefully consider the reaction conditions and purification methods to achieve high yields and desired stereochemistry.
9K
  • General Discussion
25K
