- 80
- 113
klotza submitted a new PF Insights post
All about Earth's Gravity
Continue reading the Original PF Insights Post.
... differences in the passage of time due to the differing gravitational fields ...
Both of these statements appear to be based on a common misconception. The rate of a clock does not depend on the gravitational field, but rather on the gravitational potential. Although the field is weaker at a higher potential when relating to a single central source, it is the difference in potential rather than the strength of the field which determines the time dilation. This problem seems to be limited to one paragraph, in that the following paragraphs correctly refer to the potential as determining the time dilation.... However, it is in a weaker gravitational field, so you might expect it to tick faster.
That exact point caught me off guard the day prior to this insight, I believe it was, regarding dilation of the ISS at a higher potential than the average surface of the Earth. (Zero on the gravity anomaly chart?) Being on the ISS you are moving at a faster relative velocity so clocks tick slower and being at a higher potential (and therefore less acceleration) clocks tick faster but of less magnitude than the velocity contribution. It may be the other way around? I'm not sure. This is where I need to clarify details and likely ask questions in a topic of a new thread...Jonathan Scott said:potential as determining the time dilation.
Note that higher potential doesn't always imply less gravitational acceleration. That's why it's important to understand that gravitational time dilation depends on the potential, not the gravitational acceleration.jerromyjon said:higher potential (and therefore less acceleration)
That's the direction I was heading into the shell theorem where the deeper inside the Earth you travel the effects would be opposite? Less acceleration AND lower potential?A.T. said:That's why it's important to understand that gravitational time dilation depends on the potential, not the gravitational acceleration.
klotza said:That is a good point. I will consider a better way to describe that.
M Quack said:This being a physics forum, stating the field in terms of spherical harmonics is perfectly ok, imho. Again, explicitly stating that (1-3 cos^2 theta) is the leading term in the deviation from the average might help.
Earth's gravity refers to the force of attraction between the Earth and objects on or near its surface. It is what keeps objects from floating away into space and determines the weight of objects on Earth.
Earth's gravity is measured using a unit called a "g" or "gravity unit." This unit is based on the acceleration experienced by a falling object due to Earth's gravity, which is approximately 9.8 meters per second squared (m/s²).
Earth's gravity affects objects on its surface by pulling them towards the center of the Earth. This creates a downward force, giving objects weight and keeping them from floating away. The strength of this force depends on an object's mass and the distance from the center of the Earth.
Earth's gravity is important for life on the planet because it helps to keep our atmosphere and oceans in place, allowing for the development and sustenance of life. It also plays a crucial role in the water cycle and helps to regulate Earth's temperature.
Earth's gravity can vary slightly at different locations on the planet due to factors such as variations in the Earth's shape and density. However, the overall effect of Earth's gravity remains constant and it is not expected to change significantly in the future.
