All homomorphisms from Z_n to Z_m
In summary, the problem with the original equation is that it does not take into account the gcd(m,n) value of ϕ([1]).
ArcanaNoir
779
Describe all group homomorphisms from [itex] \mathbb{Z}_n [/itex] to [itex] \mathbb{Z}_m [/itex].
[itex] \mathbb{Z}_n = {[0],[1],\dots ,[n-1]} [/itex] with addition.
A homomorphism is an operation preserving map, ie [itex] \phi (a\ast b)=\phi (a) \# \phi (b) [/itex].
One especially important homomorphism property is that [itex] \phi (a^k) = \phi (a)^k [/itex].
We can describe each homomorphism entirely by its action on any element that generate the group.
I am pretty sure there are [itex] \text{gcd}(n,m) [/itex] homomorphisms from [itex] \mathbb{Z}_n [/itex] to [itex] \mathbb{Z}_m [/itex].
Based on some examples I worked out, I believe the solution is:
let [itex] [a] [/itex] be any element which generates [itex] \mathbb{Z}_n [/itex]
[tex] \phi ([a]) = \frac{n}{\text{gcd}(n,m)}\cdot k [a] [/tex] where [itex] 0\le k < \text{gcd}(m,n) [/itex]
You are correct, but your "description" can use improvement and I believe it contains a mistake.
Let's simplify your generator a bit.
Instead of picking [a], it's easier to pick [1] as a generator.
Then candidates for the homomophisms are the ones defined by ϕ([1]).
The restriction is that ϕ(n[1]) = n ϕ([1]) = 0 mod m.
In other words m | n ϕ([1]).
Now let g = gcd(m,n), then there are numbers a and b such that ##m=ga, n=gb, \gcd(a,b)=1##.
Then:
$$ga\ |\ gbϕ([1]) \\
a\ |\ bϕ([1]) \\
a\ |\ ϕ([1])$$
Do you see why?
So you're left with the question which and how many values of ϕ([1]) meet with the condition that ##\frac m {\gcd(m,n)}## divides ϕ([1]).
I did have [1] in mind for [a], but it should work on any generator.
I'm not sure what you are getting at with your last statement.
You mentioned you thought there was a mistake, but you also said I was correct?
I believe the number of homomorphisms is indeed ##\gcd(m,n)##, but the formula you gave for ϕ([a]) is not entirely correct.
So are you saying some of the maps specified by my formula are redundant, some are missing, or some are plain wrong?
Oh bollocks! I'm saying it should be:
$$\phi([1]) = \frac m {\gcd(m,n)} k[1]$$
with ##0 \le k < \gcd(m,n)##.
Can you still smile? :shy:
This should be fun.
This should be fun.
Oops. Thanks :)
Likes 1 person
ArcanaNoir said:
Oops. Thanks :)
I guess of the choices offered, it fits "plain wrong". :biggrin:
Related to All homomorphisms from Z_n to Z_m
1. What is a homomorphism?
A homomorphism is a mathematical function that preserves the algebraic structure of a group or ring. In simpler terms, it is a function that preserves the operations and relationships between elements in a mathematical structure.
2. What is Z_n and Z_m?
Z_n and Z_m are both mathematical structures known as cyclic groups. Z_n represents the integers modulo n, while Z_m represents the integers modulo m. These structures are often used in modular arithmetic and number theory.
3. How many homomorphisms are there from Z_n to Z_m?
The number of homomorphisms from Z_n to Z_m is equal to the greatest common divisor of n and m. This is because the homomorphism must preserve the order of the elements in the group, and the order of an element in Z_n is equal to the greatest common divisor of n and m.
4. What is the kernel of a homomorphism from Z_n to Z_m?
The kernel of a homomorphism from Z_n to Z_m is the set of elements in Z_n that are mapped to the identity element in Z_m. In other words, it is the set of elements in Z_n that are mapped to 0 in Z_m. The kernel is an important concept in group theory and can be used to determine the number of homomorphisms between two groups.
5. Can a homomorphism from Z_n to Z_m be surjective?
It is possible for a homomorphism from Z_n to Z_m to be surjective, meaning that every element in Z_m has at least one preimage in Z_n. This is true if and only if m divides n, or in other words, if n is a multiple of m. In this case, the homomorphism is known as an epimorphism.
