Allowable uniform loads - W beams vs. LVL
  • Thread starter Thread starter yahastu
    Beams Uniform
The discussion focuses on comparing the maximum allowable uniform loads of steel W beams and LVL beams, highlighting that W beams have a single load limit based on span, while LVLs have multiple load conditions. A W10 x 30 beam with a 14-foot span can support 37,000 lbs, whereas a 1 3/4" x 11 1/4" 2.0E LVL with the same span supports only 4,326 lbs under total load conditions. Participants emphasize the importance of checking both live load and total load, noting that deflection often limits LVL performance compared to steel. The "BEARING" value of 1.6/4.1 indicates required support dimensions for the beam. Understanding these differences is crucial for accurate beam sizing in construction.
yahastu
I'm trying to make a comparison between the maximum allowable uniform load of a beam made of steel vs LVL.
Here is a table of allowable uniform loads for steel W beams:
https://www.engineeringtoolbox.com/w-steel-beam-uniform-load-d_1722.html
Here is a table of allowable uniform loads for LVL beams:
https://www.westfraser.com/sites/default/files/products/LVL/LVL%20Users%20Guide%20-%20US%20%20v0415.pdf
In the case of W beams, there is just 1 number for allowable load based on the span. In the case of LVLs, there is 'LL (L/360)', 'TL(L/240)', and 'BEARING.'
"To size a beam for use in a floor, it is necessary to check both live load and total load. Make sure the selected beam will work in both rows. When no live load is shown, total load will control. Spans shown are measured center-to-center of bearing."
Based on this, my understanding is that the TL(L/240) values are most comparable to the allowable load limits for the W beams.
In other words, if I'm reading this right:
A W10 x 30 beam with a 14 foot span has a maximum allowable load of 37,000 lbs, while a 1 3/4" x 11 1/4" 2.0E LVL with a 14 foot span would have a maximum Total load (L/240) of 309 lbs/LF * 14 ft = 4,326 lbs.
Please correct me if I am misunderstanding that :) Also, can anyone tell me what the "BEARING" value of 1.6/4.1 means in this case?
The allowable load of a beam is the result of several calculations:
1) Maximum bending stress
2) Maximum shear stress
3) Web crippling
4) Lateral buckling
5) Flange buckling
6) Allowable deflection
7) Point loads at connections
Every one of the above is a full chapter in a book on the subject. So, while your bold face text is probably (I did not look at your links) correct, it is not complete.
Simplified tables of allowable beam loads are useable for situations where construction details are well established, such as residential house floors. Most situations require more complete calculations.
(disclaimer,: I'm used to european building codes, so some of this stuff is new)
You should check both the total load and the live load. The live load limit is lower, because the maximal allowable deflection is lower. In general deflections are bigger with wood or lvl and this is more often the limit, where with steel the limit will tend to be the maximum bending stress or shear stress.
The bearing value of 1.6/4.1 means that you have to support the beam at the ends for 1.6 inch and in the middle for 4.1 inch. (If you use one beam for multiple spans)
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
