Alpha Lipoic Acid polymerization question
In summary, R-Alpha Lipoic Acid (RALA) is a supplement that is unstable and polymerizes at high temperatures and in the stomach. However, there are stabilized forms such as Na-RALA and K-RALA. The uptake of the ionic form is faster than the normal acid form, and the dissolution of the ionic form is also faster. It is possible to find RALA supplements with enteric coatings to prevent degradation in the stomach.
physicsnnewbie
49
I am taking R-Alpha Lipoic Acid (RALA) as a supplement, however apparently it's very unstable and polymerizes at about 40-50 degrees C and becomes unabsorbable. Apparently it also polymerizes when it reaches the stomach. There are also stabilized forms such as Na-RALA and K-RALA. Now what i want to know is what happens when this chelated form reaches the stomach. Wouldn't the RALA immediately dissociate from the cation and still polymerize? I am probably way off here, but i would much appreciate it if someone could explain to me what happens when it reaches the stomach.
Cheers.
Chemistry news on Phys.org
Cheers.
The uptake of the ionic form is faster then that the conjugate acid adding to this the rate of acidic polymerization is actually slow relative to the rate of absorption by the stomach. Also the rate of dissolution of the ionic form is faster. My guess is that the basic site has to be protonated and this also influences the rate of polymerization by the acidic route.
Thanks GCT. Are you saying the uptake of the Ionic form (NaRALA) is quicker than the normal acid form (RALA) or did i misinterpret that? If this is so why is it quicker? Also assuming the standard form RALA is not polymerized before it is injested, you saying that most of it would be absorbed before it polymerizes due to absorption being quicker than the polymerization, correct?
Cheers
Yes for the last part. The dissolution of the ionic form is faster than the acid form , as for the absorption process by the stomach itself I do not know of the biology of this I assume it has something to do with affinity or perhaps something related to ion channels.
ok thanks.
BTW, if stomach acid destroys your supplement, you just need to find a supplier that uses an enteric coating. From wikipedia:
"Most enteric coatings work by presenting a surface that is stable at the highly acidic pH found in the stomach, but breaks down rapidly at a less acidic (relatively more basic) pH. For example, they will not dissolve in the acidic juices of the stomach (pH ~3), but they will in the higher pH (above pH 5.5) environment present in the small intestine."
Use of enteric coatings is very common in the supplement industry, so it shouldn't be too hard to find an R-Alpha Lipoic Acid supplement that uses it.
Related to Alpha Lipoic Acid polymerization question
1. What is Alpha Lipoic Acid polymerization?
Alpha Lipoic Acid (ALA) polymerization is a process in which multiple molecules of ALA combine to form a long chain polymer. This process is often referred to as cross-linking and results in a larger, more complex molecule with different chemical and physical properties than the individual ALA molecules.
2. Why is the polymerization of Alpha Lipoic Acid important?
The polymerization of Alpha Lipoic Acid is important because it allows for the creation of larger molecules with more diverse properties. This can lead to enhanced stability, increased bioavailability, and improved therapeutic effects in applications such as drug delivery and tissue engineering.
3. How does Alpha Lipoic Acid polymerization occur?
ALA polymerization can occur through different mechanisms, such as radical polymerization or step-growth polymerization. In radical polymerization, free radicals are used to initiate the polymerization process, while in step-growth polymerization, two reactive groups on separate molecules join together to form a bond, resulting in the formation of a polymer chain.
4. What factors can influence the polymerization of Alpha Lipoic Acid?
The polymerization of Alpha Lipoic Acid can be influenced by several factors, including temperature, pH, solvent composition, and presence of catalysts. These factors can affect the rate and extent of polymerization, as well as the properties of the resulting polymer.
5. What are the potential applications of Alpha Lipoic Acid polymerization?
The polymerization of Alpha Lipoic Acid has potential applications in various fields, such as pharmaceuticals, biotechnology, and materials science. Some examples include the development of new drug delivery systems, tissue engineering scaffolds, and functional coatings for medical devices.
32K
49K
