Alpha particle close to the nucleus
The discussion revolves around a discrepancy in calculating the radius of an alpha particle's interaction with a nucleus, where the participant's result differs significantly from the textbook's answer. The participant initially calculated the velocity using kinetic energy but realized their value was slightly higher than expected, leading to confusion. Other contributors confirmed the textbook's solution and pointed out that the velocity calculation was unnecessary, as the kinetic energy can be directly used in the relevant formula. The key takeaway was that the participant's misunderstanding stemmed from not recognizing that the kinetic energy relates directly to the momentum formula. Ultimately, the participant corrected their approach and arrived at the correct solution.
Juli
What is the impact parameter of an alpha particle with kinetic energy 4 MeV that is deflected by the angle ##\theta = 15°## when scattered by a gold nucleus (Z =79)?
$$p = \frac{k}{mv_0^2}cot\frac{\theta}{2} $$ with $$k = \frac{2Ze^2}{4\pi\epsilon_0}$$
Hello everyone, while studying I found this task in my textbook.
Solving this problem with the help of the formula seems quite straightforward. But I get a different result than the solution the textbook offers.
I get: Around ##5∗10^{−15}m## (which is a typical solution for a radius of a nucleus)
Textbook says: ##2.16∗10^{−13}m##The point where I think I probably could be mistaken, is the velocity ##v_0##. I calculated it with ##E= \frac{1}{2}m∗v^2## with ##E=4MeV##.
Is that wrong? I get ##v_0=1.44∗10^7\frac{m}{s}## (which I think is already relativistic, so I think there is my mistake?)
Can anyone verify the solution of the textbook?
I would be very grateful for any help, since I'm quite confused.
A kinetic energy of 4 Mev is nonrelativistic for an alpha particle, which has a rest mass energy of about 3.7 Gev. For the speed of the alpha particle, I get 1.38 x 107 m/s, which is a little less than your value. This is about 5% the speed of light.
Your formula looks correct. I get the textbook's answer for the impact parameter. The only way we can identify your mistake is for you to show your calculation explicitly with all the numerical values and units for the various quantities.
Likes berkeman, PeroK and Juli
Like @TSny, I get the same answer as the text book.
Your value for ##v_0 (1.44\times 10^7m/s)## is about 4% bigger than the correct value (a small but signficant difference). You might want to sort out why.
In fact there is no need to work out ##v_0##. In the formula ##p = \frac{k}{mv_0^2}cot\frac{\theta}{2}## note that ##mv_0^2## is simply twice the kinetic energy, i.e. ##mv_0^2 = 8MeV##.
Thank you both so much.
Especially the point about ##mv^2## was very helpful. There was my mistake, I get the right solution now.
Likes berkeman and TSny
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
