Alphabetic Design Elements - or: I've had too much coffee!
  • Thread starter Thread starter DaveC426913
The discussion revolves around the creation of a unique alphabet design using a maximum of 14 defined elements, inspired by a late-night coffee-fueled brainstorming session. The designer chose Century Gothic for its simplicity and faced challenges with letters like v, x, and z due to their overlapping features, necessitating additional symmetry elements. The analysis reveals that while some letters require fewer elements, others like 'g' are over-specified, leading to inefficiencies in the design process. The theoretical minimum of element types needed to uniquely define all 26 letters is suggested to be around 4.7, prompting further exploration into the potential for fractional element types and sub-elements. The conversation highlights the complexity and creativity involved in alphabet design.
DaveC426913
This is what happens when I have coffee after 2PM. (I am not a coffee-drinker.) Did this in my head between 12 and 1AM while staring at the ceiling of my bedroom.
I've uniquely defined the letters of the alphabet with a maximum of 14 design elements.
I chose Century Gothic as a typeface with the simplest, most basic, elemental styles (sans serif and no funky tails on 'a's). I cheated with 'u'. It doesn't actually have a spine in CG, but, in my world 'u' is best defined having a spine.
I had the biggest struggle with v,x and z. Element-wise, they have a lot of overlap. I finally had to add two "Symmetry" Elements just for these cases, (which, as you will see below, is a very inefficient use of parameters).
Some are sort of default characters. 'c' requires only one element type.
Some are on the long tail of the frequency curve, with 'g' having the most elements (5). Now, that is a little over-specified - g is already uniquely-defined without needing to specify that it is counter-facing. But since I had to add 'Counter-facing' to distinguish p from d and q from b, it just incidentally applies to g. Similar thing happens for horizontal symmetry with 'i' and 'l'.
Likes Charles Link
1AM till 2AM14 element types to define 26 unique characters is not great, really. It takes .54 element-types per character, which is really wasteful.If we take a side-trip into abstracted optimization, the theoretical minimum element-types is 5. 2^5 = 32 which is enough in theory to uniqiuely define every letter:
(though they wouldn't appear in order like a binary sequence graph):
This solution is highly theoretical because it is going to be very difficult to find a mere 5 design elements that, in combination, uniquely define each of the 26 letters.
Glossary: Element
An element type has a loose set of conditions:
  • It must be a common element (i.e. 2 or more characters require it; so "x-shaped" doesn't qualify as a element type)
  • It must be a simple, basic construction element ('diagonal' is a basic element; 'shaped like a p' applies to both p and b but doesnt qualify as simple/basic).
5 elements to define 26 characters is pretty good. That's .19 element-types per character.
But even 2^5 is a little high for the theoretical minimum. (As long as we have the ability to define 32 characters uniquely, we will always wonder: what do those extra 6 possible characters look like?**)Technically, we really only need 4.7 element types (2^4.7 = 26). That gives .18 - the best possible ratio of elements to characters.
Is it possible to have a fractional element type? I think it is. Some elements are subsets of others, so they don't have complete independent range.
Ascender/descender are mutually exclusive (well, not by rule, but by there being no such character). It might be possible to formulate a sub-element type. And there's a lot of overlap between 'tail' 'arch' and 'open loop'.
More work to be done...**
https://en.wikipedia.org/wiki/On_Beyond_Zebra!
(definitely more than six!)
Look at the way Chinese characters are entered on a western keyboard.
https://en.wikipedia.org/wiki/Wubi_method
In August 1983, exactly 40 years ago, a Chinese engineer named Wang Yongmin developed the first popular way to input Chinese characters into a computer: Wubi. He did it by breaking down a Chinese character into different strokes and assigning several strokes to each letter on the QWERTY keyboard.
https://www.technologyreview.com/2023/08/23/1078274/fascinating-evolution-typing-chinese-characters/
Likes DaveC426913
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
9K
