Alternating Current Generator (Magentic Field.)
In summary: So, at t= 0 emf = 0. Thanks for all the help. Could you, or anyone else for that matter, take a look at that and see if it makes sense? Thanks!
SherlockOhms
310
An alternating current generator consisting of a rectangular loop of length a = 0.1xm and width b = 0.1ym with
N= 1w0 turns is rotated at a frequency f = 1.z Hz in a uniform magnetic field B= 0.1 T which points into the page.
A load resistance R = 10 Ω completes the generator circuit. At time t = 0, the loop is momentarily vertical (Parallel to B really).
x,y and z are known constants.
(a) What is the induced emf in the circuit at t =0?
(b) Calculate the current in the loop when it has
rotated through an angle of π/6 radians.
(c) Calculate the time-averaged power developed in
the circuit over a complete revolution.
Hint: calculate the average value of sin(2θ)
emf = NABωsin(ωt).
ω = θ(in radians) x f.
emf = IR.
The emf is 0 at t = 0 due to sin(0) = 0.
For part (b), how do you find t?
Is t = 1/f?
Finally, I calculated the average value of sin(2θ) for part (c) but have no clue where to go from there. Any suggestions would be great! Thanks.
emf = NABωsin(ωt).
emf = IR.
The equation emf = NABωsin(ωt) is a general description for this situation, but t=0 is not arbitrary.
A better form is: emf = NABωsin(ωt+)
You are going to have to think about what's happening, rather than treat this as merely a maths substitution exercise. The first step is to draw a large diagram.
Just tracking the thread ...
Ok, so I've been having a think about it and haven't made too much progress to be honest. 1) Could you explain what that blank box stands for in the eq. that you've given me?
2) So, emf = the negative of the rate of change of magnetic flux i.e. emf = -N d(∅)/dt. Which is the general formula, NABωsin(ωt). Could you explain the significance of this t? I mean, is it the time that taken to complete one revolution or part of a revolution?
ω = d(θ)/dt ⇔ θ = ωt. So, I take it that I can replace this ωt with θ?
Finally, at t = 0, the loop is vertical in the B field so the area vector of the loop is parallel/ anti-parallel to B. Thus θ = 0 (or some multiple of pi). Thus emf = NABωsin(0) which is 0. So, at t= 0 emf = 0.
For (b) I believe it's emf = IR, I = emf/R...where emf = NABωsin(θ). Also, ω = θ(in radians) x f, yes?
Sorry, that is supposed to show as the Greek symbol, Phi, standing for a phase angle.
Maybe it renders correctly here: emf = NABωsin(ωt+ɸ)
The time in seconds to complete one revolution = 1/f = 2π
where ω is in radians/sec.
When the loop is parallel to the flux lines, a tiny change in angle will cause a large change in the number of magnetic field lines passing through the loop. There is no orientation where this will be more pronounced.
Correct.
emf = NABωsin(ωt).
This is correct if the normal to the loop points into/out of page at t=0. Which I think is the case here, although the problem is very poorly worded.
No. ω = 2πf. f =1.2 Hz if I understand the problem wording. One cycle is 1/f = T seconds.
You don't.
Use your emf formula for emf with θ = ωt = π/6.
Is t = 1/f?
No, t is the time, a variable, starts at t=0 and ends whenever.
Average power over 1 cycle is ∫{(emf)2/R}dt integrated over time T, then divided by T. You have all the data you need to proceed from here.
I would ignore the hint. Can't imagine what they had in mind there.
Thanks for all the help guys. Great stuff!
Wait, are the units of time averaged power just going to be Watts or Watts/s?
Ok, so for part (b) I've calculated e=NABw(sin(theta)) where w = 2pi x f. I then divided this answer by R (10 ohms) to get the current. Apparently this is the wrong answer. I've checked the calculation a number of times so it isn't an arithmetic error. Any ideas?
Did you use π/6 for theta?
Yup.
Power is power, whether averaged or not. Power is in Watts.
DAPOS said:
Yup.
What was your answer? I want your N, A, B, w and sin(theta) too.
2.293 x10^-3. The letters w,x,y and z correspond to the values 6,2,3,6 respectively.
Not what I got. Repeat: N,A,B,w, sin(pi/6) please ...
Well, this is embarrassing...my calculator wasn't actually set to radian mode. Sorry for wasting your time man!
No prob, man, but for further action please send the parameters I asked for. :smile:
Will do! Thanks again.
FAQ: Alternating Current Generator (Magentic Field.)
What is an Alternating Current Generator?
An Alternating Current (AC) Generator, also known as an AC Generator or Alternator, is a device that converts mechanical energy into electrical energy. It uses the principle of electromagnetic induction to create an alternating current in a circuit.
How does an Alternating Current Generator work?
An Alternating Current Generator consists of a rotating magnetic field and stationary conductors. When the magnetic field rotates, it induces an alternating current in the stationary conductors. The direction of the current changes as the magnetic field rotates, resulting in an alternating current.
What are the advantages of using an Alternating Current Generator?
One of the main advantages of an Alternating Current Generator is that it can be used to transmit electrical energy over long distances. This is because AC can be easily converted into higher or lower voltages using transformers. Additionally, AC generators are more efficient and cost-effective compared to DC generators.
What are the applications of an Alternating Current Generator?
Alternating Current Generators are commonly used in power plants to generate electricity for homes, businesses, and industries. They are also used in automobiles to charge the battery and power the electrical systems. Other applications include powering electronic devices and appliances in households and providing backup power in emergency situations.
What is the difference between an Alternating Current Generator and a Direct Current Generator?
The main difference between an Alternating Current Generator and a Direct Current Generator is the type of current they produce. AC generators produce an alternating current that constantly changes direction, while DC generators produce a direct current that flows in only one direction. AC generators also use rotating magnetic fields, while DC generators use a commutator and brushes to convert mechanical energy into electrical energy.
