Alternating current LR current
In a series alternating current circuit with a generator, the phase relationship between the generator voltage and current is determined by the inductive reactance, represented as Z_L = jwL. The current lags the voltage by an angle theta due to the inductive nature of the circuit. This phase difference is crucial for understanding power factor and circuit behavior. The specific angle theta can be calculated based on the circuit's inductance and frequency. Understanding this relationship is essential for analyzing AC circuits effectively.
FARADAY JR
for a generator in a series alternating current circuit, the phase relationship between the generator voltage and current in the generator is?
N/A
the current is at some angle theta relative to the voltage.
as much help as work shown
Z_L=jwL
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
