I Alternating Harmonic Numbers are cool, spread the word!
  • I
  • Thread starter Thread starter mathhabibi
    Calculus Functions
The discussion highlights the significance of Alternating Harmonic Numbers, defined as the sum of a series that converges to ln(2) as n approaches infinity. A method to extend their domain from integers to real numbers is proposed through a telescoping series, allowing for broader applications. The derivative of the function reveals interesting properties, including a connection to the harmonic numbers and the discovery of roots that approach a specific fractional value. Additionally, a reflection formula is derived that relates the Alternating Harmonic Numbers to the Digamma function, enhancing their mathematical relevance. Overall, the conversation emphasizes the need to recognize and explore the potential of Alternating Harmonic Numbers in mathematical analysis.
mathhabibi
TL;DR Summary
Harmonic numbers, the digamma function, and a ton of special functions usually get a lot of attention, but no one cares about Alternating Harmonic Numbers. This post is intended to give them some love.
(Disclaimer: I don't know whether this type of post encouraging discussion on a function is allowed, if not please close this)
Hello PF,
If you're a fan of integrating, you'll hit a ton of special functions on the way. Things like the Harmonic Numbers, Digamma function, Exponential Integral, and things like that. One function that seldom appears in integrals (which results in it being largely forgotten) is the Alternating Harmonic Numbers. They are defined as $$\bar{H}_n=\sum_{k=1}^n\frac{(-1)^{k+1}}k$$ Clearly we have ##\lim_{n\rightarrow\infty}\bar{H}_n=\ln2## which is probably the only thing you know about it. Remember that ##n## can only be an integer. If we can extend ##\bar{H}_n##'s domain then we might be able to find some properties. How do we do it, you ask? Well, we will need a little trick. If we can turn the definition of ##\bar{H}_n## into an infinite series by continually adding and subtracting terms (i.e. make an infinite series that telescopes to ##\bar{H}_n##), then ##n## will no longer be in the upper bound and ##\bar{H}_n## would have a bigger domain. This telescoping series turns out to be $$\bar{H}_x=\sum_{k=1}^\infty\left(\frac{(-1)^{k+1}}k-\frac{(-1)^{k+1+x}}{k+x}\right)$$Note that we changed ##n## to ##x## because soon enough ##x## won't need to be an integer. I say soon enough because there is a ##(-1)^x## in the second fraction still forces ##x## to be an integer, but we can replace ##(-1)^x=\cos(\pi x)## and sum the first fraction to get $$\bar{H}_x=\ln2-\cos(\pi x)\sum_{k=1}^\infty\frac{(-1)^{k+1}}{k+x}$$We can stop here because now ##x## can be any real number except the negative integers. The infinite series can be rewritten, but before doing that, let's make a few observations. Notice how letting ##x=k+\frac12## for some ##k\in\mathbb{Z}## results in ##\bar{H}_x=\ln2##. Another thing is that, if we take the derivative of ##\bar{H}_x## with respect to ##x## and then let it be equal to ##0##, then we get that ##\bar{H}_0'=\frac{\pi^2}{12}##. This seems cool and all, but ##H_0'=\frac{\pi^2}6##, where ##H_x## represents the harmonic numbers, defined similarly like ##\bar{H}_x## but without the alternating symbol. One more thing we should talk about before rewriting the infinite sum is the roots of ##\bar{H}_x##. This is only a graphical observation, but take a look at this graph and focus on the three digits after the decimal point:
Notice here that, after many roots, the fractional part seems to approach ##-0.431##. I have no clue why this is true, but here's an interesting coincidence: $$\int_0^1\frac{\bar{H}_x\bar{H}_{-x}\sin(\pi x)}{\pi x}dx\approx0.431415917919$$The inspiration behind multiplying the sine function divided by ##\pi x## is because this is another way of writing ##\frac1{\Gamma(1-x)\Gamma(1+x)}## which removes the poles of ##\bar{H}_x\bar{H}_{-x}##. Notice here that, not only are the first three decimal digits 431, but there is a 314159 inside the decimal string, giving five accurate decimal digits of ##\pi##. This is most likely a coincidence because the ##1## after the last ##\pi## digit is fixed as the lower bound goes to ##0##. Now you might wonder why the lower bound wasn't equal to zero, and this is because of how I rewrote the infinite sum. So here it is: $$\sum_{k=1}^\infty\frac{(-1)^k}{k+x}=\psi(x)-\psi\left(\frac x2\right)-\frac1x-\ln2$$Where ##\psi## is the digamma function. When I have time I will write the proof of this in a different post (it's a little long). The important thing about this is that we can derive a reflection formula for ##\bar{H}_x## :$$\bar{H}_x-\bar{H}_{2-x}=\pi\cot(\pi x)-\left(\frac1{2-x}-\frac1{1-x}-\frac1x\right)\cos(\pi x)$$No special functions involved. Notice that the first term of the RHS is the reflection formula for the Digamma function. Also note that ##\psi(0)## is undefined, so I had to make the lower bound approach ##0## instead.
One more thing about ##\bar{H}_x## is that using the Euler-Maclaurin expansion to make a domain extension isn't that great because the integral involved will have to cross the singularities of ##\frac{\cos (\pi x)}{t+x}##, which are infinitely many, making it defined only when ##x>-1##. The analytic continuation by simply rewriting ##\bar{H}_x## as a telescoping series doesn't have this issue.
If you have anything else about the Alternating Harmonic Numbers, post them here! This function is very underrated so please spread the word :)
Mathematics news on Phys.org
I accidentally called the png "roots of harmonic numbers". They aren't as interesting as the roots of the alternating harmonic numbers just as a heads up.
Okay, so here's how to rewrite the infinite sum. First, notice that $$\sum_{k=0}^\infty\frac{(-1)^k}{k+x}=\sum_{k=0}^\infty\left(\frac1{2k+x}-\frac1{2k+1+x}\right)$$Two tricks here: Add and subtract a ##\frac1{2(k+1)}## and reorder: $$\sum_{k=0}^\infty\left(\frac1{2k+x}-\frac1{2k+1+x}\right)=\sum_{k=0}^\infty\left(\frac1{2(k+1)}-\frac1{2k+1+x}-\left(\frac1{2(k+1)}-\frac1{2k+x}\right)\right)$$Factoring out the ##\frac12## and rewriting using the definition of the digamma function, we get that the infinite series is ##\frac12\left(\psi\left(\frac{x+1}2\right)-\psi\left(\frac x2\right)\right)##. This is still not what we want, but for that just take the derivative of the logarithm of the Gauss multiplication formula and we're done (then we need to subtract ##\frac1x## because we started the sum from ##k=0##).
I solved the conjecture. Take a look at the function ##\bar{H}_x-\bar{H}_{2-x}+\ln2##, which is just the RHS of the reflection formula added by ##\ln2##. As ##x\rightarrow-\infty## we have that ##\bar{H}_x-\bar{H}_{2-x}+\ln2\sim\bar{H}_x## and the RHS approaches ##\ln2+\pi\cot(\pi x)##. So we have that ##\ln2+\pi\cot(\pi x_n)\sim0## where ##x_n## is the ##n##th largest root of ##\bar{H}_x##. Solving for ##x_n## we get that ##x_n\sim-n-\frac1{\pi}\arctan\left(\frac\pi{\ln2}\right)## and so the fractional part is ##\eta=-\frac1{\pi}\arctan\left(\frac\pi{\ln2}\right)##. I had a feeling it wasn't too hard to solve all along.
There's a small typo in the OP but I couldn't change it. The reflection formula should be $$\bar{H}_x-\bar{H}_{2-x}=\pi\cot(\pi x)+\left(\frac1{2-x}-\frac1{1-x}-\frac1x\right)\cos(\pi x)$$But this doesn't change the proof of the conjecture.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
