Alternative material to the springs used in furniture
In summary: Doesn't need to fit into existing designs- Can use almost any type of material- Priority given to being sustainable- Can be made with local labor/resources- Timeframe is not a limiting factor- No cost limit
mttrm0
TL;DR Summary
I am looking for a cheaper, mass-produced material as an alternative to s-spring used in furniture.
Hello guys,
I started as a R&D engineer in a furniture factory. The factory asked me to find an alternative material to the s-spring and turn it into a project. This material can also be produced and should be cheaper than spring steel. The S-spring is made of 1070 and 1090 spring steels. In order for the material to be used instead of a spring, it must have sufficient strength and sufficient elasticity. The yield strength of 1070 steel is between 400 and 540 Mpa. Its tensile strength is between 620 and 700 Mpa and elongation at break is 10%. If you have alternative material suggestions for this steel, please could you share it?
Thank you.
Kind you regards.
Welcome to PF.
How long is your product expected to last ?
How long do you warrant your product ?
A synthetic strap like seat belt webbing is the obvious choice. Almost any spring constant can be engineered by the choice of warp and weft material in the webbing.
Likes mttrm0
Baluncore said:
Welcome to PF.
First of all, thank you very much for your response.
- It should be a material that can last up to at least 15 years.
- It should be a product that can be guaranteed for 10 years.
First of all, what you said is very logical, varieties with elastic upholstery fabrics are used in furniture today. There are some disadvantages of using elastic woven columns as suspension. If the columns are not stretched very well, easy collapses occur and it is a product with high labor costs.
Unless you wish to use the original 's-spring' shape, these parameters does not mean much. You need to aim for the functionality and strength displayed by the spring, instead of the properties of steel.
Feels difficult. Cheap plastics (cheaper than steel) are likely out of the picture, both as solids and pressurized shapes.
Maybe some flexible wood constructs?
It would seem sensible to use a local product, to reduce transport costs and encourage the local economy.
What is the availability of materials like bamboo, hemp or flax?
Well, there's this option:
https://yogibo.com/collections/bean-bag-chairs
From where I sit (pun fully intended :wink:), you've got a bunch of options, which doesn't help much in your effort. So, let's answer some questions to help narrow down the scope of the project....
  • What restrictions do you have other than life limits?
  • Does it have to fit into existing designs, or is it only for new designs?
  • What material types can you use?
  • Is sustainability a factor/priority?
  • Does the product need to be made with local labor/resources?
  • What's the development timeframe?
  • Is there a cost limit?
FAQ: Alternative material to the springs used in furniture
What are some common alternative materials to springs used in furniture?
Some common alternative materials to springs in furniture include high-density foam, memory foam, latex, and elastic webbing. These materials can provide similar support and comfort without the need for traditional metal springs.
How does high-density foam compare to springs in terms of support and durability?
High-density foam offers excellent support and durability, often outperforming traditional springs in terms of longevity. It conforms to the body's shape, providing even support and reducing pressure points. However, it may not have the same level of bounce or resilience as metal springs.
Is memory foam a good alternative to springs in furniture?
Memory foam is a popular alternative to springs due to its ability to contour to the body and provide personalized support. It is particularly beneficial for reducing pressure points and improving comfort. However, it may retain heat and can be more expensive than traditional spring-based furniture.
What are the advantages of using latex as an alternative material to springs in furniture?
Latex is a highly durable and resilient material that offers excellent support and comfort. It is also naturally hypoallergenic and resistant to dust mites and mold. Latex provides a more responsive feel compared to memory foam, making it a good alternative to springs for those who prefer a bouncier surface.
How does elastic webbing compare to springs in furniture construction?
Elastic webbing is a flexible and durable material often used in modern furniture construction. It provides good support and can be easier to install and maintain compared to traditional springs. While it may not offer the same level of firmness as metal springs, it is a cost-effective and lightweight alternative.
