Alternative Method for Solving ∫sin(3x)cos(5x)dx?
In summary: And high five for you too!)In summary, the given integral can be solved by using the product formula or by using the identities for $\sin(3x)$ and $\cos(5x)$. Another alternative is to transform the integral and use integration by parts twice.
paulmdrdo1
385
another trig problem that i tried to solve. just want know an alternative way of solving this without using product formula.
$\displaystyle\int \sin(3x)\cos(5x)dx$
anyways this is how i solved it
$\displaystyle\int\frac{1}{2}\sin(3x-5x)+\frac{1}{2}\sin(3x+5x)dx$
$\displaystyle\int\frac{1}{2}\sin(-2x)+\frac{1}{2}\sin(8x)dx$
$\displaystyle\frac{1}{2}\int\sin(-2x)dx+\frac{1}{2}\int\sin(8x)dx$
$\displaystyle u=-2x$; $\displaystyle du=-2dx$; $\displaystyle dx=-\frac{1}{2}du$
$\displaystyle v=8x$; $\displaystyle dv=8dx$; $\displaystyle dx=\frac{1}{8}dv$
$\displaystyle-\frac{1}{4}\int\sin(u)du+\frac{1}{16}\int\sin(v)dv$
$\displaystyle -\frac{1}{4}(-\cos(-2x))+\frac{1}{16}(-\cos(8x))+C$
$\displaystyle \frac{1}{4}\cos(-2x)-\frac{1}{16}\cos(8x)+C$ ---- this is my answer.
the -2x part in this answer is bothering me because in my book it's not negative. please tell me why is that.
paulmdrdo said:
The $-2x$ part in this answer is bothering me because in my book it's not negative. Please tell me why is that.
Because $\cos$ is an even function. That is, $\cos(-x)= \cos(x)$ for all $x$.
is there another way of solving this? please let me know.
Hello, paulmdrdo!
Is there another way of solving this?
. . [tex]\displaystyle \int \sin(3x)\cos(5x)\,dx[/tex]
There is . . . but you won't like it!Identities:
. . [tex]\sin(3x) \:=\:3\sin x - 4\sin^3\!x[/tex]
. . [tex]\cos(5x) \:=\:5\cos x - 20\cos^3\!x + 16\cos^5\!x[/tex]Hence:
.[tex]\sin(3x)\cos(5x) \,=\, (3\sin x\!-\!4\sin^3\!x)(5\cos x\!-\!20\cos^3\!x\!+\!16\cos^5\!x)[/tex]
. . [tex]=\;15\sin\cos x - 60\sin x\cos^3\!x + 48\sin x\cos^5\!x[/tex]
. . . . . [tex]- 20\sin^3\!x\cos x + 80\sin^3\!x\cos^3\!x - 64\sin^3\!x\cos^5\!x [/tex]Now integrate that term by term.
\(\displaystyle \int \sin(ax) \cos(bx) \, dx \)
Can be transformed to
\(\displaystyle \frac{1}{a}\int \sin(x) \cos(c x) \, dx \)
Try integration by parts twice .
Soroban, you a meenie! Bad mammal! (Sun)(Devil)
EDIT:
[ps. High five? (Wasntme) ]
You wouldn't even need to transform. Just integrate by parts twice and "solve" for the integral.
FAQ: Alternative Method for Solving ∫sin(3x)cos(5x)dx?
What is integration of trigonometric functions?
Integration of trigonometric functions is a mathematical process of finding the anti-derivative of a given trigonometric function. It is the reverse operation of differentiation, and involves finding the original function when its derivative is known.
Why is integration of trigonometric functions important?
Integration of trigonometric functions is important because it allows us to solve a wide range of problems in mathematics, physics, and engineering. It is used to find areas, volumes, and other physical quantities in real-life applications.
What are the basic rules for integrating trigonometric functions?
The basic rules for integrating trigonometric functions include using trigonometric identities, applying the power rule, using the substitution method, and using integration by parts. These rules are used to simplify the integral and find the anti-derivative of the given function.
How do you integrate trigonometric functions with multiple angles?
To integrate trigonometric functions with multiple angles, we use the double angle, half angle, and sum or difference formulas. These formulas help to simplify the integral and express the function in terms of a single trigonometric function.
Are there any common mistakes to avoid when integrating trigonometric functions?
One common mistake to avoid when integrating trigonometric functions is forgetting to add the constant of integration. It is also important to double check the signs and use the correct trigonometric identities and formulas. Another mistake to avoid is applying the wrong rule or formula for a given function.
