Alternator run at zero power factor lagging
An alternator cannot operate at zero power factor lagging purely inductively due to inherent losses and resistance in the stator winding. Shorting the leads may increase reactance, but achieving a phase shift beyond 45° is challenging. The user is measuring voltage and current phase angles using an oscilloscope and a 14 gauge wire, but increasing excitation current has not yielded the desired results. The discussion highlights the limitations of passive components in achieving a purely inductive state. Ultimately, achieving a zero power factor lagging operation in an alternator is likely impractical.
electricalguy
Hello, I'm wondering if it's possible to make an alternator run at zero power factor lagging (purely inductive). I was researching this topic and apparently by shorting the leads of the alternator the output will become fully reactive. Yet I've attempted this on a small scale and the most I can get the phase between voltage and current to shift is 45°. I've increased the excitation current without a change in the phase angle. Is there something I'm missing? Is there a way I can make the alternator run purely inductive? I understand lagging power factor is demagnetizing, leading power factor is magnetizing and unity power factor is cross magnetized. Is the issues with the resistance of the stator winding?
In reality - I doubt this is possible with passive components as there will always be real losses.
If you are shorting the output - how are you measuring the voltage in taking the PF?
I'm using an oscilliscope to take measurements of the line voltage and the phase current. I used a 14 gauge wire to connect the phases together. I measure the current waveform across the 14 gauge wire. I measure the difference in time between the voltage and current waveforms in milliseconds, then divide by one AC cycle in milliseconds, then multiple by 360 and this gives me the phase angle between the two in degrees.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
