Does Aluminum Coating on Telescope Mirrors Turn into Aluminum Oxide?
In summary, large telescope mirrors have aluminum reflective coatings that are usually overcoated with silicon monoxide to increase reflectivity and improve coating life. The aluminum oxide layer formed when aluminum corrodes actually serves as a protective layer for the underlying aluminum, making it an excellent coating for telescope mirrors. This is the standard practice for most reflecting telescopes, including amateur ones.
anorlunda
Staff Emeritus
Insights Author
11,308
8,744
I saw on Nova thst large telescope mirrors have aluminum reflective coatings. Wouldn't that rapidly become an aluminum oxide costing?
Are the coatings coated to keep oxygen out?
Astronomy news on Phys.org
Yes, when aluminum corrodes it forms a layer of aluminum oxide on the surface that protects the rest of the underlying aluminum from corroding. Aluminum oxide is transparent to visible light, so it makes an excellent coating for telescope mirrors.
anorlunda
pretty much all mirrors on reflector telescopes are aluminised even small scopes used for amateur use
I have 3 reflecting scopes with mirrors of 6", 8' and 9.25 " They all have an aluminium coating and then other coatings on top of that to protect the aluminium coating
and that is pretty much the standard :smile:
cheers
Dave
Aluminum coatings are usually overcoated with silicon monoxide, or something similar. This is a good idea for a couple of reasons - increased reflectivity and improved coating life.
I can confirm that aluminum oxide coatings are commonly used on telescope mirrors as a reflective surface. This is because aluminum oxide is a highly reflective material that can withstand the harsh conditions of space. However, there is a misconception that the coating will rapidly become aluminum oxide itself.
While it is true that aluminum will naturally oxidize when exposed to oxygen, the coating on telescope mirrors is designed to prevent this from happening. The aluminum is typically coated with a layer of protective material, such as silicon dioxide, that acts as a barrier to oxygen. This ensures that the aluminum remains reflective and does not become aluminum oxide.
In addition, the coatings are carefully applied in a controlled environment to minimize any exposure to oxygen. This helps to maintain the reflective properties of the aluminum and prolong the lifespan of the coating.
So to answer your question, the coatings on telescope mirrors are not coated to keep oxygen out, but rather to prevent the aluminum from oxidizing and maintain its reflective properties.
FAQ: Does Aluminum Coating on Telescope Mirrors Turn into Aluminum Oxide?
What is aluminum oxide coating?
Aluminum oxide coating, also known as alumina coating, is a thin layer of aluminum oxide applied on the surface of a material to enhance its properties such as corrosion resistance, hardness, and thermal stability.
How is aluminum oxide coating applied?
Aluminum oxide coating can be applied through various methods such as chemical vapor deposition, physical vapor deposition, and anodizing. These methods involve the use of heat, electricity, or chemical reactions to deposit the coating onto the surface of the material.
What are the benefits of using aluminum oxide coating?
Aluminum oxide coating offers several advantages, including corrosion resistance, abrasion resistance, increased hardness, and improved thermal stability. It also provides a protective barrier against environmental factors, extending the lifespan of the coated material.
What are the applications of aluminum oxide coating?
Aluminum oxide coating is commonly used in industries such as aerospace, automotive, electronics, and medical devices. It is also used in household items such as cookware and appliances, as well as in construction materials like windows and doors.
Is aluminum oxide coating environmentally friendly?
Yes, aluminum oxide coating is considered to be environmentally friendly as it does not contain harmful substances and can be easily applied using eco-friendly methods. Additionally, the coating's durability and corrosion resistance contribute to the sustainability of the coated materials, reducing the need for frequent replacements.
