Aluminum Potassium Sulfate Hazards?
  • Thread starter ArcanaNoir
  • Tags
    Aluminum
In summary, Aluminum Potassium Sulfate is a chemical commonly used in crystal growing kits. While it may cause slight irritation to the skin, it is generally considered safe for use. It has been used in various cosmetic, culinary, and medicinal applications. However, it has also been implicated in some health concerns, such as Alzheimer's disease. The MSDS for this substance is similar to other commonly used substances, such as citric acid, and its potential hazards may be overrepresented in safety documents. However, in high concentrations, it can be harmful and has been involved in accidents in water treatment plants. Overall, it is generally considered a safe substance for students to handle in small amounts.
ArcanaNoir
779
Is anyone familiar with Aluminum Potassium Sulfate? We have a "crystal growing kit" at school, and this is the chemical used to grow the crystals. Since some of my students have conduct disorders, I wanted to know more about the chemical before I permitted the project. I read the hazard codes, but I'm looking for a more "straight dope" description of the hazards of this chemical. What exactly happens if you touch it? If someone licked a crystal, would it actually be necessary to call poison control? (I'm not going to let anyone lick it. In fact, I'm almost certainly going to prohibit this project. I'm just looking for some justification, if it exists.)
Chemistry news on Phys.org
Fishing rod: google "Aluminum Potassium Sulfate MSDS"
Fish: this is quite safe substance. Some may find it slightly irritating to the skin, but the same can be said about kitchen salt. Just washing hands should be enough in the case any symptoms appear (which is as far as I remember quite unlikely, I did similar lab eons ago, I think the effect I remember was that the skin got a little bit dry and harsh). No reported toxicity, so even if they swallow some there should be no problems. Compare http://en.wikipedia.org/wiki/Alum - plenty of cosmetic/culinary/medicinal uses.
Well, I've heard that you can keep your cat from eating your parakeet with it. (starts at 2:20 min.)
Seriously though, it's a pretty safe chemcal... one of the few remaining ones that students can play with. It used to be formed into a stick and sold as a styptic pencil. Cut yourself shaving? Press the pencil against the cut and it stops bleeding immediately (for small cuts).
If you want an excuse not to use it, you can always say that aluminum salts are implicated with Alzheimers.
Quote from Flinn's MSDS:
Call a physician, seek medical attention for further treatment, observation and support after first aid.
Inhalation: Remove to fresh air at once. If breathing has stopped give artificial respiration immediately.
Eye: Immediately flush with fresh water for 15 minutes.
External: Wash with soap and water.
Internal: Give large quantities of water. Call a physician or poison control at once.
Would you dare to try to guess what substance requires such measures?
Substance not considered hazardous. However, not all health aspects of this substance have been thoroughly investigated.
Would you guess what chemical they described this way? (Same First Aid Measures listed, seems like they put exactly the same information everywhere.)
They sell to schools, their MSDSs are there to cover their back.
Edit: I see chemisttree did exactly the same, just faster :smile:
It is used in water treatment plants for clarifying water. At low concentrations it is ok but some accidents have occurred fairly recently (in Britain)where huge quantities were dumped in the water system and illness occurred in people drinking the tap water supplied.
FAQ: Aluminum Potassium Sulfate Hazards?
What is aluminum potassium sulfate?
Aluminum potassium sulfate, also known as potassium alum, is a chemical compound commonly used in many industrial and household products such as antiperspirants, deodorants, and food additives. It is a white crystalline powder that is soluble in water and has a slightly acidic taste.
What are the hazards associated with aluminum potassium sulfate?
Aluminum potassium sulfate is considered to be a relatively safe chemical, but it can still pose some hazards. It is a skin and eye irritant and can cause irritation if inhaled or ingested. It may also cause allergic reactions in some individuals. In large doses, it can be toxic to the kidneys and liver.
How can exposure to aluminum potassium sulfate be prevented?
To prevent exposure to aluminum potassium sulfate, it is important to follow safety precautions when handling the chemical. This includes wearing protective equipment such as gloves, goggles, and a mask. It is also important to use the chemical in a well-ventilated area and to avoid ingesting or inhaling it.
What should I do if I come in contact with aluminum potassium sulfate?
If you come in contact with aluminum potassium sulfate, immediately wash the affected area with soap and water. If the chemical gets into your eyes, flush them with water for at least 15 minutes. If you experience any symptoms such as irritation or difficulty breathing, seek medical attention.
Is aluminum potassium sulfate safe for the environment?
Aluminum potassium sulfate is considered to be relatively safe for the environment. However, if large amounts are released into the environment, it can be harmful to aquatic life. It is important to dispose of the chemical properly and to avoid any spills or leaks.
