Aluminum wire stretched four times longer, resistance?
In summary, multiplying by 16 instead of 4 when making a new wire results in a wire with twice the resistance at 20 degrees Celsius.
redsealelectron
A piece of aluminum wire has a resistance of 20C, 15.5 [tex]\Omega[/tex]. If this wire is melted down and used to produce a second wire having a length four times the original length, what will the resistance of the new wire be at 20C? (Hint: The volume remains the same)
R = [tex]\rho[/tex][tex]\stackrel{l}{a}[/tex]
or
R2 = R1(1 + [tex]\alpha[/tex]1[t2 - t1])
R2 = R1(1 + 0)
R2 = R1 * 4
R2 = 62.0
I have plugged in the information into equation number two. As the delta t = 0, I didn't use the temperature coefficient. My answer was to multiply the initial resistance by 4, which gave me 62.0 [tex]\Omega[/tex].
Some guys in my class are saying that you have to multiply by 16, and the correct answer is 248 [tex]\Omega[/tex].
I don't see why they would multiply by 16, sure its four times longer, but does that mean the diameter of the wire went down? The volume of the wire remained constant, so I assume yes, it did get longer increasing the resistance by four, but the volume remained the same so that is all that is needed.
Can anyone see if I have missed something?
The volume of the wire is A*L, where A is the cross-sectional area and L is the length. So if volume is constant and you multiply the length by four, what happens to the cross-sectional area and how do A and L relate to total resistance.
Increasing the length increases the resistance of the wire by a factor of four. If the cross sectional area increases by a factor of four then the resistance should decrease by a factor of 16... this would be r2 = 1/4R1?
Noooo. If L->4*L then A->A/4 so the product (which is volume) stays constant. The area DECREASES.
So the wire is now four times longer, and is now thinner then it was orginally. The cross sectional area is smaller therefore the resistance is higher then it was. So i must use R = p(L/A)? will I have to solve for the diameter of the wire?
Yes, that's exactly what you need. L is four times bigger, A is four times smaller. You don't need the diameter. What happens to R?
Its multiplied by 16, because the length has increased by four and the area has decreased by four, initial resistance * the decreased area of four * the increased length of four?
Yes. Your friends were right. For practice, what happens to the diameter? If you say it decreases by a factor 2, you would be right.
Dick, thank you for your help and letting me work through the problem. I have a better understanding now.
No problem. Always fun if the victim of my advice finally 'gets it'.
Related to Aluminum wire stretched four times longer, resistance?
1. What is the relationship between the length of aluminum wire and its resistance when stretched four times longer?
When aluminum wire is stretched four times longer, its resistance will increase four times. This is because resistance is directly proportional to the length of the wire.
2. How does the diameter of the aluminum wire affect its resistance when stretched four times longer?
The diameter of the aluminum wire does not have a significant effect on its resistance when stretched four times longer. The resistance is primarily determined by the length and material of the wire.
3. Will the resistance of the aluminum wire change if it is stretched to a different length?
Yes, the resistance of the aluminum wire will change if it is stretched to a different length. As mentioned earlier, resistance is directly proportional to the length of the wire. Therefore, the longer the wire is stretched, the higher its resistance will be.
4. How does the type of material used for the aluminum wire affect its resistance when stretched four times longer?
The type of material used for the aluminum wire will have a significant impact on its resistance when stretched four times longer. Different materials have different resistivity values, which determine their resistance. Therefore, using a different material for the wire will result in a different resistance when stretched to the same length.
5. Is there a limit to how much the resistance of aluminum wire can increase when stretched four times longer?
Yes, there is a limit to how much the resistance of aluminum wire can increase when stretched four times longer. This limit is determined by the maximum resistivity of the material used. Once the wire reaches its maximum resistivity, its resistance will not increase further, even if it is stretched longer.
