Am i wrong or is it the book? Newtonian physics two stacked masses
In summary, the 2.0 kg block will not slip on a 4.0 kg block if the applied force of 2.0 kg is reduced to half. If the applied force is doubled, the block will move at an 8.019 m/s^2 acceleration.
clark1089
A 2.0 kg block rest on a 4.0kg block that is on a frictionless horizontal table. The coefficients of friction are u_s = 0.3 and u_k = 0.2. What is the maximum force F that can be applied to the 4.0 kg block if the 2.0 kg block is not to slip? If F has half this value, find the acceleration of each block and the force of friction acting on each block .If F is twice the value you determined in the first question, find the acceleration of each block.
Fx = F = m1a
Fx = ff = m2a
What I need help with is the final part of this problem... part C. Here's what is needed to solve:
I solved for 18 N in part(a), the first part, as the maximum force required to move the object.
Now, I solved for the acceleration of block 2 in the last part; block 2 = ff/m2 = u_k*g = (.2)(9.81) = 2.0 m/s^2
But now I'm trying to solve for the acceleration of the 4.0kg block
F - ff = m1a1 + m2a2
(F - ff - m2a2)/m1 = a1 = 7.019 m/s^2
Not right... the book says it is 7.9 m/s^2. So I tried again ignoring ff
(F - m2a2)/m1 = a1 = 8.019 m/s^2
where am i going wrong here? sorry, no diagram given in problem so I can't scan one.. :X:X
i note that, although they list 18 N as the force, if you leave it unrounded:
17.76 *2 = 35.52
35.52 - m2 = m1a1
35.52 - 4 = 4a
a = 7.88 = 7.9 m/s^2
that can't be it, can it?
Fx = F = m1a
Fx = ff = m2a
17.76 *2 = 35.52
35.52 - m2 = m1a1
35.52 - 4 = 4a
You are not drawing Free Body Diagrams (FBD), which are essential to the solution. For the last part, draw a FBD of the bottom block (isolate that block), and look at the forces in the x direction acting on that block. The applied Force F acts right, and the friction force ff acts left. The mass of the block is m1. Solve for a1 using Newton 2. Note that in this diagram and equation for the bottom block, m2 does not come into play.
...wow! thank you! :D i got the right answer :)
Related to Am i wrong or is it the book? Newtonian physics two stacked masses
1. Am I wrong if I don't understand Newtonian physics?
No, understanding Newtonian physics can be challenging for many people, and it takes time and practice to fully grasp the concepts. It's important to ask questions and seek out resources to help you better understand the principles.
2. Is Newtonian physics still relevant today?
Yes, Newtonian physics is still widely used and applied in many fields, including engineering, astronomy, and everyday life. It provides a strong foundation for understanding the motion and forces of objects.
3. Can I apply Newtonian physics to everyday situations?
Yes, Newtonian physics can be applied to everyday situations, such as calculating the force needed to push a shopping cart or understanding the motion of a falling object. It helps us understand the physical world around us.
4. What are the two stacked masses in Newtonian physics?
The two stacked masses refer to a common example used in Newtonian physics, where two objects with different masses are placed on top of each other and the force of gravity between them is calculated using Newton's Law of Gravitation.
5. Are there any limitations to Newtonian physics?
Yes, Newtonian physics has its limitations, particularly at very small scales (such as in the world of atoms and particles) and at very high speeds (such as near the speed of light). In these cases, other theories such as quantum mechanics and Einstein's theory of relativity are needed to fully explain the behavior of objects.
