AM transmission tower signal rectified in electric arc to generate audio
In summary, this short YT video is about how you can hear the audio modulation of an AM transmitter by looking for an arc in the intensity of the sparks.
davenn
2023 Award
9,655
10,793
This short YT video isnt about the AM rectification, it was about why you dont touch transmitter towers
I just noted that the audio of the signal could be heard as the guy was generating an arc
Pretty cool .....
cheers
Dave
  • Wow
Likes Klystron, DaveE, dlgoff and 1 other person
Perhaps a closer description than 'rectified' would be 'demodulated' or 'detected'.
You could hear the audio because AM is Amplitude Modulation. That means the instaneous instantaneous transmitted power is proportional to the audio waveform amplitude at that instant in time.
At zero audio amplitude (silence or zero-crossing of the audio waveform) the transmitter is emitting its nominal power - for instance a 1kW transmitter is putting out 1kW.
If the transmitter is being 100% modulated, the positive peaks of the audio cause the transmitter to emit 2kW; and the negative audio peaks cause Zero transmitter emission.
This power variation causes the arc intensity to vary as the incoming audio varies, thus allowing you to hear the audio modulation.
Enter Amplitude Modulation into Google search for more than you ever wanted to know.
Likes Klystron and berkeman
You could hear the audio because AM is Amplitude Modulation. That means the instaneous transmitted power is proportional to the audio waveform amplitude at that instant in time.
All good info :smile:
yes, I am a radio operator / technician :smile: :smile:
got my license back in the days of long answers and drawing circuit diagrams
Likes berkeman
FAQ: AM transmission tower signal rectified in electric arc to generate audio
What is the principle behind AM transmission tower signals being rectified in an electric arc to generate audio?
The principle involves the modulation of an amplitude-modulated (AM) signal being intercepted by an electric arc. The arc acts as a non-linear medium that rectifies the high-frequency carrier wave, demodulating it and allowing the audio frequency signal to be heard. Essentially, the arc functions similarly to a crystal detector in early radio receivers.
How does an electric arc detect and demodulate AM signals?
An electric arc can detect and demodulate AM signals because it acts as a diode, allowing current to pass more easily in one direction than the other. When an AM signal passes through the arc, the high-frequency carrier wave is rectified, and the audio signal, which is the modulation of the carrier, becomes audible. This process is akin to the way early radio sets used crystal detectors to demodulate signals.
What are the safety concerns associated with using an electric arc to generate audio from AM signals?
Safety concerns include the risk of electrical shock, burns, and fire hazards due to the high voltage and current required to sustain an electric arc. Additionally, the arc produces ultraviolet light and ozone, which can be harmful to health. Proper shielding, ventilation, and safety protocols are essential when experimenting with electric arcs.
Can any AM transmission tower signal be rectified by an electric arc to generate audio, or are there limitations?
Not all AM transmission tower signals can be effectively rectified by an electric arc to generate audio. The effectiveness depends on factors such as the strength of the AM signal, the frequency of the carrier wave, and the properties of the electric arc. Stronger signals with lower carrier frequencies are more likely to produce audible audio through an arc.
Is it possible to improve the audio quality generated by an electric arc from AM signals?
Improving the audio quality generated by an electric arc from AM signals can be challenging due to the inherent noise and instability of the arc. However, using a more stable and controlled arc, optimizing the distance between the electrodes, and minimizing interference can help enhance audio clarity. Additionally, using filters to suppress unwanted frequencies may improve the overall audio quality.
