Am vs Fm variable capacitor receiver, what is the difference?
The discussion clarifies the role of variable capacitors in AM and FM receivers, emphasizing their function in LC resonant circuits. In both cases, these circuits allow for tuning to specific frequencies, with AM typically resonating around 1 MHz and FM around 100 MHz. The modulation type influences the detector used, but not the tuning method. A variable capacitor adjusts the resonant frequency to select desired signals within the bandwidth of each modulation type. Ultimately, both AM and FM receivers utilize variable capacitors to effectively tune into radio frequencies.
sol47739
TL;DR Summary
What is the difference between a variable capacitor in a AM receiver and a variable capacitor in a FM receiver?
What is the difference between a variable capacitor in a AM receiver and a variable capacitor in a FM receiver? I understand that Am is amplitude modulation and that the signal is carried over a changing amplitude and that the frequency is constant. And the opposite in FM signals. And a variable capacitor is a capacitor which you can change in order to match the signal you want to receive. When an antenna receives a FM wave the currents acceleration will change according to the absorbed wave and when an antenna receives an AM wave the acceleration of the charges will be the same but the amount of „electrons“ that get accelerated are larger. Thus the voltage over the capacitor changes. So I can kind of understand that you can have a capacitor and tune it in to the right amount of electrons that get accelerated in the FM case, since the amplitude is constant and thus the amount of electrons that will „build up“ on one side of the capacitor. Am I thinking correct? But how does a variable capacitor work in the AM case, when the frequency is constant?
You are confused and not thinking about it in the easiest way.
A variable capacitor is used with an inductor to form an LC resonant circuit. At resonance, energy circulates between the electric field of the capacitor and the magnetic field of the inductor. The resonant frequency is adjusted, with the variable capacitor, to select the wanted radio signal.
https://en.wikipedia.org/wiki/LC_circuit
For the AM broadcast band, the LC circuit will be resonant at about 1 MHz.
For the FM broadcast band, the LC circuit will be resonant at about 100 MHz.
The form of modulation employed decides the type of detector needed, not the method used for tuning the RF signal.
Likes berkeman and DaveE
Regardless of the modulation method, it has a certain bandwidth, so a tuned circuit is needed to selectively receive signals within this bandwidth range, and the most basic form of this circuit is an LC resonant circuit, even an antenna can be regarded as It is an LC circuit, adjusting C can select the channel of different radio stations.
Likes sophiecentaur and DaveE
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
