MHB Amanda's question at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion revolves around calculating the volume of the solid formed by rotating the area between the curves y=4x-x^2 and y=x about the y-axis using the cylindrical shells method. The limits of integration are determined to be x=0 and x=3, leading to the volume formula V=2π∫(3x^2-x^3)dx from 0 to 3, resulting in a volume of 27π/2. An alternative approach using the washer method is also presented, confirming the same volume through two separate integrals. Both methods yield consistent results, demonstrating the reliability of the calculations. The conversation encourages further calculus inquiries from participants.
MarkFL
MHB
Here is the question:
Calculus homework help?
Using the cylindrical shells method of integral calculus...what is the the volume bounded between y=4x-x^2 and y=x after a rotation across the y axis? Thank you!
Here is a link to the question:
Calculus homework help? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello amanda,
The first thing I like to do is create a sketch of the region to be revolved:
https://www.physicsforums.com/attachments/855._xfImport
Now, let's first determine the limits of integration by equating the two curves:
$$4x-x^2=x$$
Write in standard quadratic form:
$$x^2-3x=0$$
Factor:
$$x(x-3)=0$$
Hence $$x=0,\,3$$.
Now, the volume of an arbitrary shell is:
$$dV=2\pi rh\,dx$$ where
$$r=x$$
$$h=4x-x^2-x=3x-x^2$$
and so we have:
$$dV=2\pi x\left(3x-x^2 \right)\,dx=2\pi\left(3x^2-x^3 \right)\,dx$$
Now, summing the shells, we find:
$$V=2\pi\int_0^3 3x^2-x^3\,dx$$
Applying the anti-derivative form of the fundamental theorem of calculus, there results:
$$V=2\pi\left[x^3-\frac{1}{4}x^4 \right]_0^3=2\pi\left(3^3-\frac{3^4}{4} \right)=54\pi\left(1-\frac{3}{4} \right)=\frac{27\pi}{2}$$
I like to check my work by using another technique, and in this case we may use the washer method. This will mean setting up two integrals, one in which the line is the outer radius, and another in which the right side of the parabola is the outer radius. The left side of the parabola is the inner radius in both cases. We will need to solve the parabola for $x$. Writing it in vertex form, we have:
$$y=-(x-2)^2+4$$
$$(x-2)^2=4-y$$
$$x-2=\pm\sqrt{4-y}$$
$$x=2\pm\sqrt{4-y}$$
Interval 1: $$0\le y\le3$$
The volume of an arbitrary washer is
$$dV_1=\pi(R^2-r^2)\,dy$$ where:
$$R=y$$
$$r=2-\sqrt{4-y}$$
and so we have:
$$dV_1=\pi\left(y^2+y+4\sqrt{4-y}-8 \right)\,dy$$
Summing by integration:
$$V_1=\pi\int_0^3 y^2+y+4\sqrt{4-y}-8\,dy$$
$$V_1=\pi\left[\frac{1}{3}y^3+\frac{1}{2}y^2-\frac{8}{3}(4-y)^{\frac{3}{2}}-8y \right]_0^3=\pi\left(\left(9+\frac{9}{2}-\frac{8}{3}-24 \right)-\left(-\frac{64}{3} \right) \right)=\frac{49\pi}{6}$$
Interval 2: $$3\le y\le4$$
$$dV_2=\pi(R^2-r^2)\,dy$$ where:
$$R=2+\sqrt{4-y}$$
$$r=2-\sqrt{4-y}$$
and so we have:
$$dV_2=8\pi\sqrt{4-y}\,dy$$
$$V_2=8\pi\int_3^4\sqrt{4-y}\,dy$$
$$V_2=-\frac{16\pi}{3}\left[(4-y)^{\frac{3}{2}} \right]_3^4=-\frac{16\pi}{3}\left(0-1 \right)=\frac{16\pi}{3}$$
Now, adding the two volumes, we find:
$$V=V_1+V_2=\frac{49\pi}{6}+\frac{16\pi}{3}=\frac{27\pi}{2}$$
This agrees with the result we found using the shell method.
To amanda and any other guests viewing this topic, I invite and encourage you to post other calculus questions here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
