Ambient temperature energy generation
In summary, heat pumps are known to create more energy than they consume by transferring heat from one place to another. However, it is not possible to extract all of the energy released from the compressor to generate electricity, and attempting to do so would violate the laws of physics. The efficiency of heat engines and heat pumps are opposite functions of temperature difference, making it impossible to have a 115% COP coupled with a 90% efficiency. Therefore, such a device is not economically viable and this logic is flawed.
beamthegreat
116
It is known that heat pumps create more energy than it consumes due to moving "heat" from one place to another. For example, if an air conditioner consumes 100 watts, the compressor will release 120 watts of heat since the heat in the room will be transferred to the compressor.
Would it then be possible to extract the energy released from the compressor to generate electricity? This doesn't violate the conservation of energy since the energy is derived from the ambient temperature (The net temperature in the atmosphere will decrease to compensate for the energy we obtain).
Is this logic flawed? Would such a device be possible and economically viable?
Science news on Phys.org
Not more than the compressor needs. The same advantage you have for heat pumps is a disadvantage for the opposite direction.
It would reduce entropy, which is against the laws of physics, too.
No, such a device is impossible. There is no loophole, it is pointless to ask "would it work if ...?".
Why wouldn't it? A normal compressor would generate the same amount of energy as it would consume. Of course, we cannot extract as much energy as it needs since the generator or heat engine cannot be 100% efficient and some energy is loss as sound, EM radiation, vibrations, etc. However, the total energy released from the system must equal the energy we put into the compressor.
Now if we used this compressor to move heat from the outside air into the machine, there would be more energy that it started with. Suppose the energy it release is 115% and is released as heat. Could we use the best technology we currently have to extracte 90% of the 115% of the energy it consume back as electricity? We would then have 3.5% energy left.
Could anyone explain how this logic is flawed?
beamthegreat said:
Why wouldn't it?
The efficiency of heat engines and heat pumps are opposite functions of temperature difference: a greater temperature difference increases the efficiency of the heat engine, but decreases the efficiency of the heat pump.
Logic explained above. For the numbers, rather than pulling them out of the air, you should plug them into the heat pump and heat engine efficiency equations. Then you'll see that you can't have a 115% COP coupled with a 90% efficiency.
Alright thanks. I now realized how flawed this idea is. :smile:
Related to Ambient temperature energy generation
What is ambient temperature energy generation?
Ambient temperature energy generation is the process of converting the energy present in the surrounding environment, typically in the form of heat, into usable electricity. It utilizes the temperature difference between a heat source and a heat sink to generate electricity through thermoelectric materials.
How does ambient temperature energy generation work?
Ambient temperature energy generation works by utilizing the Seebeck effect, which is the phenomenon where a temperature difference between two dissimilar conductors creates an electrical voltage. This voltage can then be converted into usable electricity through a thermoelectric device.
What are the advantages of ambient temperature energy generation?
One of the main advantages of ambient temperature energy generation is its ability to generate electricity from a readily available and renewable source of energy. It also has no moving parts, making it low maintenance and reliable. Furthermore, it has a small footprint and can be integrated into existing systems or devices.
What are the limitations of ambient temperature energy generation?
One limitation of ambient temperature energy generation is its relatively low efficiency compared to other forms of energy generation. It also requires a significant temperature difference between the heat source and heat sink to produce a meaningful amount of electricity. Additionally, the cost of materials used in thermoelectric devices can be a barrier to widespread adoption.
What are some applications of ambient temperature energy generation?
Ambient temperature energy generation can be used in a variety of applications, including waste heat recovery in industrial processes, powering small electronic devices, and even generating electricity from body heat. It can also be integrated into buildings to supplement their energy needs and reduce reliance on traditional energy sources.
  • Thermodynamics
