Ambient temperature on production floor
In summary: That's going to depend on how the air gets warmed up.Cold outside air that is passed through a heat exchanger to warm it up will contain the same amount of moisture at it did before being heated, relative humidity will be lower. Passing this air over cold equipment should not cause a condensation problem.
Dorin
If normal ambient temperature on production floor is 65-70°F, would there be noticeable effects on production floor equipment if we drop ambient down to 35-40°F? Equipment consists of motors, PLC's, VFD's, process instrumentation ie flow meters, chart recorders, level sensors/transmitters, pressure sensors/transmitters, temperature sensors/transmitters, 316 & 304 stainless steel sanitary tubing, enclosed fluorescent lighting, fire suppression sprinkler heads and any other standard food plant production equipment. The temperature would be brought down over a period of a couple of hours using a positive air flow equipment bringing in outside filtered air with burners off. Since outside air would be below freezing, inside ambient should reach 35-40°F fairly quickly. After about an 8 hour production run at the lowered temperature, we would bring back inside ambient to 65-70°F as quickly as our positive air flow equipment will allow(it is strictly outside air passing through filters then heated, no return). Is there a possibility of negatively affecting instruments or other equipment by attempting this drastic change in ambient temperature? Thank you in advance for taking the time to read and offer input.
Science news on Phys.org
I wouldn't expect any problems but would check that all impulse lines are free from condensation in case you ever get below freezing. I would check data sheets for the manufacturers data sheets just in case.
Likes Dorin
How many times are you planning on doing this? If it's just a time or two, I agree with Jobrag. But, if you want to do this for all production days from now on, that kind of temperature cycling may cause electro-mechanical fatigue in some of your equipment, shortening the lifetime of that equipment.
This is intended to happen once a year for the duration of one 8-12 hour shift (we run 2 daily shifts year round). Then it's back to normal ambient of 65-70°F.
Warm humid air coming into contact with cold soaked metal might cause condensation to form. Perhaps hang a cold metal plate in front of the incoming vents and check for condensation? Not sure what to recommend if you get some. Air conditioning?
If the heating process involves unvented burners of some sort the exhaust from the burners will contain water vapor which could condense on cold equipment.
Thank you all; the test should happen next week. I'll post an update soon thereafter.
Related to Ambient temperature on production floor
1. What is considered the ideal ambient temperature for a production floor?
The ideal ambient temperature for a production floor is typically between 68-72°F (20-22°C). This temperature range allows for comfortable working conditions for employees and is also optimal for most manufacturing processes.
2. How does ambient temperature on the production floor affect product quality?
Ambient temperature can have a significant impact on product quality. Extreme temperatures, either too hot or too cold, can cause product defects or failures. It is important to maintain a consistent ambient temperature to ensure consistent product quality.
3. What measures can be taken to regulate ambient temperature on the production floor?
There are several measures that can be taken to regulate ambient temperature on the production floor. These include using air conditioning or heating systems, proper insulation, and ventilation. It is also important to monitor and adjust the temperature regularly to maintain a consistent level.
4. Are there any safety concerns related to ambient temperature on the production floor?
Extreme ambient temperatures can pose safety risks for employees on the production floor. High temperatures can lead to heat stress, while low temperatures can increase the risk of hypothermia. It is essential to monitor and regulate the ambient temperature to ensure the safety and well-being of employees.
5. How does ambient temperature on the production floor impact energy efficiency?
The ambient temperature on the production floor can have a significant impact on energy efficiency. Extreme temperatures can cause heating or cooling systems to work harder, resulting in higher energy consumption. Maintaining a consistent ambient temperature can help to reduce energy costs and improve overall efficiency.
9K
26K
  • General Discussion
