Ambiguity in the Arc-Tangent Function
  • MHB
  • Thread starter bw0young0math
  • Tags
    Function
In summary: In general, people think of the angles $\theta$ as depending on the coordinates (x,y), but I think it is better to look at the coordinates as depending on the angle. So you have to think, "given $x$ and $y$, what is the angle $\theta$?" And the answer is, "the angle $\theta$ is the arctangent of $y/x$".In summary, the conversation discusses the ambiguity of the arctangent function and how it can give different results depending on the quadrant. It is explained that this is due to the tangent function having a period of pi and not 2pi. The use of x and y in the numerator or denominator is also explained as a way to find
bw0young0math
27
This problem is about complex analysis.
Why arctan(5/-5) is different from arctan-1(-5/5)?
tan-1(5/-5)=3ㅠ/4 +2kㅠ
tan-1(-5/5)=-1ㅠ/4+2kㅠ (k :arbtrary integer.)
Why can't I calculate just arctan(-1)?I thought that it is related withe tangent peoriod ㅠ not 2ㅠ.
However I can't know that exactly.
Please help me...
Mathematics news on Phys.org
Re: Ambiguity in the Arc Tangent Function
You are correct in that the problem arises from the tangent function having period $\pi$ and not $2\pi$. Because of that, your calculator may not give you the correct quadrant when it computes the inverse (arctan). You have to think to yourself, "Hmm. My $x$ is positive, so I have to be in either the first or the fourth quadrant. $y$ is negative; therefore, I must be in the fourth quadrant." Actually, if you ask your calculator to compute
$$\arctan(-5/5)\quad \text{and} \quad \arctan(5/(-5)),$$
it will give you the same result both times. One of them is in error, however. Some programming languages get around this by implementing the atan2 function, which takes two arguments and returns the correct quadrant.
At first, thanks for your help. :eek:
I understood your meaning that they have same values consequently. Right?
However, arctan(5/(-5)) can't express -ㅠ/4. Thus I can't understand why they are the same.Also,you mentioned about x, y, and quadrant.
My friend and I thought the reason arctan(5/(-5)) and arctan((-5)/5) are different as discussing x,y,and quadrant also.
However we didn't know why we put one of x and y denominator or numerator. Could you explain this?
It's essentially an order of operations problem. As it happens, $-5/5=5/(-5)=-1$, so the argument to the arctan function is the same in both cases.
This arises when you are attempting to find the magnitude and direction of a 2D vector from its components. Equivalently, you are converting from rectangular coordinates to polar, either with real number or with the complex numbers.
The forward direction is
\begin{align*}
x&=r \cos( \theta)\\
y&=r \sin( \theta).
\end{align*}
If you divide the second of these by the first, you get
$$ \frac{y}{x}= \tan( \theta).$$
Taking the arctangent of both sides yields the usual equation
$$ \theta= \arctan \left( \frac{y}{x} \right).$$
So the reason $y$ is in the numerator, is because this is the correct transformation from rectangular coordinates to polar.
The ambiguity in the arc-tangent function arises from the fact that it is a multi-valued function. This means that for a single input value, there can be multiple possible output values. In the case of arctan(5/-5) and arctan-1(-5/5), the difference in output values is due to the different branches of the arc-tangent function that are being used.
In the first case, arctan(5/-5), we are using the principal branch of the arc-tangent function, which is defined to have values between -π/2 and π/2. This is why the result is 3π/4.
In the second case, arctan-1(-5/5), we are using the other branch of the arc-tangent function, which is defined to have values between -π and π. This is why the result is -π/4.
As for calculating arctan(-1), it is important to specify which branch of the arc-tangent function you are using. If you are using the principal branch, the result would be -π/4. However, if you are using the other branch, the result would be 3π/4. It is important to clarify which branch is being used to avoid ambiguity.
FAQ: Ambiguity in the Arc-Tangent Function
What is the arc-tangent function?
The arc-tangent function, also known as the inverse tangent function, is a mathematical function that calculates the angle in radians between the positive x-axis and a given point on the unit circle. It is denoted as tan-1(x) or arctan(x).
How is ambiguity defined in the arc-tangent function?
Ambiguity in the arc-tangent function refers to the fact that for a given input value, there can be multiple possible output angles. This is because the tangent function is periodic, meaning it repeats itself after every 180 degrees or π radians. Therefore, the inverse tangent function can have infinitely many solutions.
How do you handle ambiguity in the arc-tangent function?
To handle ambiguity in the arc-tangent function, we typically restrict the output range of the function to a specific interval. This can be done by using the principal value, which is the angle between -π/2 and π/2. This ensures that the output is a single, unique value and avoids any confusion or errors.
Can the arc-tangent function have negative values?
Yes, the arc-tangent function can have negative values. This is because the tangent function can have negative values for certain angles, and the inverse tangent function simply takes the inverse of that value. However, by convention, the principal value of the arc-tangent function is typically restricted to the range of -π/2 to π/2, so the output will never be negative.
What are some real-life applications of the arc-tangent function?
The arc-tangent function has many applications in fields such as engineering, physics, and computer science. It is commonly used in trigonometric calculations for determining angles and distances, as well as in signal processing and control systems. It is also used in computer graphics and animation to rotate objects in 2D and 3D space.
