Ammeters and voltmeters in series
  • Thread starter Thread starter Tanishq Nandan
    Series
When an ammeter and voltmeter are connected in series to a cell, the initial readings indicate zero current and the full emf of the cell across the voltmeter due to the voltmeter's high resistance. Introducing a resistor in parallel with the voltmeter allows current to flow, increasing the ammeter's reading while decreasing the voltmeter's reading. The discussion highlights that the voltmeter's reading decreases because the potential difference across the battery changes when current flows, assuming the battery is not ideal. The conclusion reached is that the correct answer to the problem is D: the ammeter reading increases while the voltmeter reading decreases. This reflects the impact of non-ideal conditions on the measurements.
Tanishq Nandan
An ammeter and a voltmeter are joined in series to a cell.Their readings are A and V respectively.If a resistance is now joined in parallel with the voltmeter,
A)both A and V will increase
B)both A and V will decrease
C)A will decrease,V will increase
D)A will increase,V will decrease
[/B]
Basic theory behind ammeters and voltmeters:
▪Ammeter:Used for measuring current.In essence,it is a galvanometer (current detecting device) attached to a very small resistance attached to it in parallel(small so that it doesn't hinder the current it is measuring and gives an accurate reading)
▪Voltmeter:Used for measuring potential difference.In essence,it is a galvanometer with a very high
resistance attached to it in series (High so that it doesn't allow current to flow through it,which would change the amount of current across the element being measured, and correspondingly change the potential difference across it,preventing us from getting an accurate reading)
[/B]
An ideal voltmeter has a resistance of infinity,so when it is connected with a cell in series,along with an ammeter,the only path for current to traverse the entire circuit would be through the voltmeter,but the high resistance wouldn't allow it to flow.
So,the initial readings according to me ought to read:
[Assuming emf of cell to be E]
A=0 (no current through the circuit)
V=E (potential across its two ends)
Now,as soon as we connect a resistor through it,it provides the current a path to flow,so now we have a current flowing through the circuit.
So,final readings according to me should be:
[Assuming resistance connected to be R]
A=E/R(which is obviously greater than before)
V=?HERE LIES MY PROBLEM?
Isn't the potential difference across the two ends same as before??
Answers D by the way,so hopefully my method of deducing A was right(If it wasn't,please do inform me)
But,I am stuck on V.
Yes, as long as you assume the source is an ideal one with no internal resistance. Why do you see this as a problem?
Any time you get stuck on this kind of problem you should draw a circuit diagram and label it will all known conditions (and if you have, as you do here, two different set of conditions, draw it twice).
Coz the answer given is D:A increases,whereas V decreases.There isn't any option for V remains same,which is bugging me.
So, you need to decide. Am I wrong or is the question using an unstated assumption?
What is V? And what is E?
There's no E...A and V are the readings on the ammeter and voltmeter respectively.
E is the emf of the cell.
What will remain unchanged? V or E?
cnh1995 said:
E is the emf of the cell.What will remain unchanged? V or E?
According to me,V
According to me,V
Why? And why not E?
cnh1995 said:
Why? And why not E?
Okk,yeah,I get your point,the potential difference across the terminals of a battery change as soon as current flows through it.(If the battery isn't ideal,of course)
So either the battery isn't ideal or the meters aren't ideal. (Or both aren't ideal).
Then D sounds correct to me.
