Ammonia acts as a base in aqueous solution
In summary, ammonia is a colorless gas with a sharp, pungent odor that is commonly used in cleaning products and fertilizers. When dissolved in water, it acts as a weak base, accepting protons from water to form hydroxide ions. The pH of an aqueous solution of ammonia is typically around 11, making it a weak base. Ammonia is considered a weaker base compared to other strong bases like sodium hydroxide or potassium hydroxide, but it is still stronger than water itself. Some common uses of ammonia as a base include household cleaning products, fertilizers, and the production of chemicals, textiles, and plastics.
a.a
127
Ammonia acts as a base in aqueous solution; Kb is equal to 1.8 x 10-5. What is the Ka for the ammonium ion NH4+ in aqueous solution?
I am totally lost for this question, can someone please start me off? all i know is that Kw = Ka * Kb
You are given Kb, you should remember Kw value - just solve for Ka.
I can provide some insights into this question. First, let's define some terms. Ammonia (NH3) is a weak base, meaning it does not fully dissociate in water. When ammonia is dissolved in water, it reacts with water molecules to form ammonium ions (NH4+) and hydroxide ions (OH-). This reaction is reversible, meaning that some of the ammonium and hydroxide ions can combine to form ammonia and water again.
The equilibrium constant for this reaction is called the base dissociation constant (Kb). It is a measure of how much ammonia dissociates into ammonium and hydroxide ions in water. In this case, we are given that Kb for ammonia is equal to 1.8 x 10^-5. This means that for every 1 mole of ammonia in solution, 1.8 x 10^-5 moles of ammonium and 1.8 x 10^-5 moles of hydroxide ions are formed.
Now, the question asks for the Ka of the ammonium ion, which is the equilibrium constant for the reaction between ammonium and water to form ammonia and hydronium ions (H3O+). This reaction is also reversible, and the equilibrium constant is related to Kb by the following equation: Kw = Ka * Kb. We know that Kw (the autoionization constant of water) is 1.0 x 10^-14, so we can rearrange the equation to solve for Ka: Ka = Kw / Kb.
Plugging in the value for Kb (1.8 x 10^-5), we get Ka = (1.0 x 10^-14) / (1.8 x 10^-5) = 5.6 x 10^-10. This is the Ka for the ammonium ion in aqueous solution. It tells us how much ammonium dissociates into ammonia and hydronium ions in water.
I hope this explanation helps to clarify the question and guide you in finding the answer. Remember, as a scientist, it's important to understand the concepts behind the equations and not just plug in numbers. Good luck!
FAQ: Ammonia acts as a base in aqueous solution
What is ammonia?
Ammonia, chemical formula NH3, is a colorless gas with a sharp, pungent odor. It is composed of one nitrogen atom and three hydrogen atoms and is commonly used in cleaning products and fertilizers.
How does ammonia act as a base in aqueous solution?
When ammonia is dissolved in water, it forms ammonium hydroxide (NH4OH), which is a weak base. This means that in aqueous solution, ammonia accepts a proton from water, resulting in the formation of hydroxide ions (OH-).
What is the pH of an aqueous solution of ammonia?
The pH of an aqueous solution of ammonia is typically around 11, making it a weak base. This is because the ammonium ion formed from the reaction of ammonia and water is a weak acid, so the solution will have a slightly basic pH.
How does the strength of ammonia as a base compare to other bases?
Ammonia is considered a weak base, meaning it does not fully dissociate in water and has a lower tendency to accept protons compared to strong bases like sodium hydroxide or potassium hydroxide. However, it is still a stronger base than water itself.
What are some common uses of ammonia as a base?
Ammonia is used as a base in many household cleaning products, as well as in fertilizers to provide essential nitrogen for plant growth. It is also used in the production of various chemicals and in the manufacturing of textiles and plastics.
