Ammonium hydroxide Percent to normality conversion
  • Thread starter KKAK
  • Tags
    Percent
In summary, 10% v/v of ammonium hydroxide is the appropriate concentration to make a 0.3N solution from the stock Fluka solution.
KKAK
Hi all,
I was trying to make a 0.3N ammonium hydroxide solution from the stock (Fluka). The label on the stock says it is "10% assay in water", what does it mean? Is it 10% v/v? How should I prepare a 1ml 0.3N ammonium hydroxide? I don't quite understand the solute mass equivalent concept of normality.
Thank you
Chemistry news on Phys.org
You could call the company and find out how they specify the assay. For solid solutes, the assay is typically w/w and for liquid solutes it is often v/v. In this case though, the solute is a highly soluble gas (NH3), and it might turn out that they are using a molar % instead.
As for converting molarity to normality, you need to understand the concept of an equivalent weight. The primary question to ask yourself is this: If I dissociate 1 formula unit of the compound, how many electrons are transferred between the cationic part and the anionic part?
To be more rigorous, the normality is a function of the reaction that the compound is involved in. For some compounds, the normality for a given molarity can be different under different situations. In the case of NH4OH though, this is unlikely.
Commercially available solutions are almost always listed as w/v. I've never seen it expressed otherwise. Thus 37.5% hydrochloric acid would be 37.5 grams HCL in 100 mL of solution. It makes the calculations easiest that way since you can weigh an aliquot of the stock solution and dilute to a known volume to obtain your solution.
My bad! :redface:
I haven't needed to know the exact concentration of any of the reagents I've used in a long time. The three concentrations I commonly use are: really dilute, straight from the bottle and on the rocks, please! :biggrin:
0.3N?
Isn't that M?
FAQ: Ammonium hydroxide Percent to normality conversion
What is ammonium hydroxide and how is it used in science?
Ammonium hydroxide, also known as ammonia solution, is a clear, colorless liquid with a strong odor. It is used in many scientific experiments and processes, such as in the production of fertilizers, as a cleaning agent, and as a reagent in various chemical reactions.
What is the difference between percent and normality in the context of ammonium hydroxide?
Percent refers to the concentration of a substance in a solution, while normality is a measure of the number of equivalents of a substance per liter of solution. In the case of ammonium hydroxide, percent is calculated by dividing the mass of ammonium hydroxide by the total mass of the solution, while normality is calculated by dividing the number of equivalents of ammonium hydroxide by the volume of the solution in liters.
Can percent be converted to normality for ammonium hydroxide?
Yes, percent can be converted to normality for ammonium hydroxide by using the following formula: normality = (percent/100) x (molar mass/grams of acid per equivalent). This conversion is necessary when performing titrations or other experiments that require a specific normality of ammonium hydroxide.
How do I convert ammonium hydroxide from normality to percent?
To convert ammonium hydroxide from normality to percent, use the formula: percent = (normality x grams of acid per equivalent) / (molar mass x 100). This conversion may be needed when working with solutions that are measured in percent rather than normality.
Are there any safety precautions that should be taken when working with ammonium hydroxide?
Yes, ammonium hydroxide is a corrosive substance and can cause irritation to the skin, eyes, and respiratory tract. It is important to wear proper protective equipment, such as gloves and goggles, when handling this chemical. It should also be stored and disposed of properly according to safety guidelines.
