AlexVI
- 4
I have 10mm thick film with dielectric constant of 3. Let’s say surface area of the film is 50 ft2. On the surface of the film I will deposit thin conductive layers with different resistivity. On the first sample of the film I will deposit thin layer with the sheet resistance of 10 ohm/in^2. On the second sample - 100 ohm/in^2 and third sample 1000 ohm/in^2. How does resistivity of deposited layers will affect the amount of charge that this structure can store if I use it in two electrode configuration where this structure is connected to a negative terminal and thin metal plate (with the same surface area) parallel to the structure is connected to positive terminal.
