Amount of possible public keys in RSA Cryptosystems
  • MHB
  • Thread starter Marceline
In summary: N) will always be even. This is because the only prime factors of φ(N) are (p-1) and (q-1), which are both even numbers. Therefore, the number of possible public keys for any given modulus N will always be an even number.c) It is possible to choose p and q in such a way that the totient (φ) of their product (N) is even, which would result in an even public key. One way to do this is by choosing p and q to be twin primes, which are two prime numbers that differ by 2 (e.g. 41 and 43). In this case, the totient
Marceline
Good day to everyone. I need a little help by the following task please:
Task
p und q are two different primes
a) How many possible public keys exists for the RSA-Cryptosystems with modul N = p * q?
b) Show additionally to a), that the amount of possible public keys is an even numberc) Is it possible to chose p and q that way, that there is an even public key?
Justify your answers. Without any justification, you will receive 0.00 points on the task.
My personal approach:
A public key is simply an e ∈ℤφ(N), which is relatively prime to φ(N), for example:
p = 7 and q = 13, then N is = 7*13 = 91
and φ(N) = (7-1) * (13 - 1) 72
Then, e.g. e = 5 is a public key, because 5 ∈ ℤφ(72) because 5 is relatively prime to φ(91), so it is relatively prime to 72.
So the answer would be "all possible public keys, which are releatively prime to φ(N)". But the task, ask "how many" public keys, and the task No b) gives us the hint, that the number of possible keys is an even number (which I have to show seperately). So they ask for a concrete number. How can I do this, when p and q any variables.
Mathematics news on Phys.org
Thank you for your post. I am happy to assist you with your task.
a) To answer your first question, we need to understand the concept of the RSA-Cryptosystem. In this system, the public key (e) is a number that is relatively prime to the totient (φ) of the modulus (N). The modulus (N) is the product of two distinct prime numbers (p and q). Therefore, the number of possible public keys is equal to the number of positive integers that are relatively prime to φ(N).
To calculate the totient (φ) of N, we use the formula φ(N) = (p-1)(q-1). So for example, if p = 7 and q = 13, then N = 91 and φ(N) = 72. The number of positive integers that are relatively prime to 72 is equal to the number of positive integers that are not divisible by 2, 3, or 9 (since these are the prime factors of 72).
To find the number of positive integers that are not divisible by 2, 3, or 9, we can use the principle of inclusion and exclusion. This states that the number of positive integers that are not divisible by any of these numbers is equal to the sum of the number of positive integers that are not divisible by 2, the number of positive integers that are not divisible by 3, the number of positive integers that are not divisible by 9, minus the number of positive integers that are not divisible by both 2 and 3 (since we would have counted them twice).
Using this principle, we can calculate that there are 24 positive integers that are not divisible by 2, 18 positive integers that are not divisible by 3, and 8 positive integers that are not divisible by 9. However, we need to subtract the number of positive integers that are not divisible by both 2 and 3, which is 12. Therefore, the total number of positive integers that are relatively prime to 72 is 24 + 18 + 8 - 12 = 38.
So for the given example, there are 38 possible public keys for the RSA-Cryptosystem with modulus N = 91.
b) To show that the number of possible public keys is an even number, we need to consider the fact that if p and q are two distinct primes
FAQ: Amount of possible public keys in RSA Cryptosystems
How many possible public keys are there in an RSA cryptosystem?
The number of possible public keys in an RSA cryptosystem is infinite. This is because the public key is generated by choosing two large prime numbers, and there are an infinite number of prime numbers.
Is there a limit to the number of public keys that can be generated in an RSA cryptosystem?
Technically, there is no limit to the number of public keys that can be generated in an RSA cryptosystem. However, due to practical limitations such as the size of the prime numbers used, there is a limit to the number of unique public keys that can be generated.
How does the size of the prime numbers affect the number of possible public keys in an RSA cryptosystem?
The size of the prime numbers used in an RSA cryptosystem directly affects the number of possible public keys. As the size of the prime numbers increases, the number of possible public keys also increases exponentially.
Can two different public keys have the same value in an RSA cryptosystem?
No, two different public keys cannot have the same value in an RSA cryptosystem. Each public key is unique and is generated by different combinations of prime numbers.
How does the number of possible public keys in an RSA cryptosystem compare to the number of possible private keys?
The number of possible public keys in an RSA cryptosystem is significantly larger than the number of possible private keys. This is because the public key is generated by two prime numbers, while the private key is generated by a combination of these prime numbers and an additional value. Therefore, the number of possible private keys is a subset of the number of possible public keys.
