Ampere's Law for Cylindrical Conductor
The discussion revolves around the application of Ampere's Law to a cylindrical conductor, specifically addressing the calculation of enclosed current. The user calculates the current density for the outer tube and the area of the enclosed portion but questions the correctness of their area expression. Clarification is sought on whether Ra represents the inner or outer radius of the tube, which is crucial for accurate area calculation. The user combines the inner and outer currents to find the total enclosed current but receives feedback indicating an error in their approach. The conversation highlights the importance of correctly identifying geometric parameters in electromagnetic calculations.
amwil
A solid cylindrical conductor is supported by insulating disks on the axis of a conducting tube with outer radius Ra = 6.85 cm and inner radius Rb = 3.75 cm . (Figure 1) The central conductor and the conducting tube carry equal currents of I = 2.85 A in opposite directions. The currents are distributed uniformly over the cross sections of each conductor. What is the value of the magnetic field at a distance r = 4.74 cm from the axis of the conducting tube?
What is the expression for the current Iencl enclosed in the path of integration in terms of the current I , the outer radius Ra , the inner radius Rb , and the distance from the axis r where Ra>r>Rb ?
Express your answer in terms of I , Ra , Rb , and r .
I = JA
I know that Ienl for the inner cylinder is just I and the current density for the outer tube is J1= -I/(pi(Ra^2-Rb^2). I assume that the current through the enclosed portion of the conducting tube (I1) is equal to J1(A1) where A1 is the area of the enclosed portion of the conducting tube. I found A1=pi(Ra^2-r^2) then multiplied it by J1 to get I1 = (-I(Ra^2-r^2))/(Ra^2-Rb^2). Then I added Iencl for the inner cylinder and I1 for the outer tube to get Iencl= I + (-I(Ra^2-r^2))/(Ra^2-Rb^2) but it said this was wrong. Can someone tell me what I'm doing wrong??
OK
OK
Are you sure this is the correct expression for the area of the enclosed portion of the tube?
To be more explicit: Is ##R_a## the inner radius or is it the outer radius of the tube?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
