B Amplifier or oscillator for a vibration generator
For constructing a Chladni plate, an audio oscillator is recommended as the signal source rather than an oscilloscope, which only analyzes signals and lacks the necessary output power. An audio power amplifier is essential to amplify the oscillator's signal to effectively drive the vibration generator, which functions similarly to a loudspeaker. It's important to select an oscillator with a suitable frequency range and sufficient power, ideally around 2 watts or more, to achieve adequate displacement at sub-audio frequencies. A DIY alternative involves using a model electric motor with an eccentric load and a variable voltage power supply, which can be measured with an oscilloscope. This approach offers a cost-effective solution while providing a solid foundation for future experiments.
arosinblum
I purchased this vibration generator to construct a Chladni plate. I was hoping to use it with my existing oscilloscope (which appears to be very old). It seems the oscilloscope is not giving me a signal strong enough to drive the generator. Any suggestions for a different amplifier or power signal generator that wont break the bank but will be powerful enough to drive the vibration generator?
Oscilloscope? Maybe you mean audio oscillator.
The vibration generator is basically a loudspeaker.
Use the audio oscillator as the signal source.
Use an audio power amplifier to amplify the oscillator, and to drive the vibration generator.
A normal oscilloscope doesn't produce signals. It analyses them. A suitable audio oscillator needs to be fairly powerful to get a decent displacement of that transducer at sub-audio frequencies. The type of oscillator needs to have a suitable frequency range so it needs to be like the one mentioned on the link. A general purpose audio oscillator may not do the job so be careful of the spec of anything you may need to buy second hand.
A DIY version of a LF vibration generator can be made with a model electric motor with an eccentric load and a variable voltage power supply. You can measure the frequency with your oscilloscope. Not the best but quite a bit cheaper and a good base for future experiments.
I think you need, say, 2 watts or more of audio power to drive one of these. I have used a Chladni plate with the very same vibration generator as you describe.
Likes sophiecentaur
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
