forestmine
- 203
A string with both ends held fixed is vibrating in its third harmonic. The waves have a speed of 192m/s and a frequency of 240 Hz. The amplitude of the standing wave at an antinode is .4cm.
Calculate the amplitude at points ont he string a distance of (i) 40cm, (ii) 20cm, and (iii)10 cm from the left end of the string.
A*sin(kx)sin(ωt)
k=2[itex]\pi[/itex]/λ
λ=v/f
I'm assuming I need to use the equation for the position along a wave, given as A*sin(kx)sin(ωt). I'm thinking I need to set it up so that my only unknown is A. I started by solving for λ and then k. From there, I can find ω. I'm not sure, however, how to continue without knowing my time t. Also, when it says that the amplitude of the standing wave is .4cm, does that entail my maximum amplitude, and therefore all of the amplitudes I come up with should be points within this max displacement? And even if I have a given t, I still don't quite understand how to use the standing wave equation. In this form in particular, its solution entails the position, so is it simply A*sin(kx)sin(ωt)=the position at those given conditions.
Any direction would be greatly appreciated.
