Automotive Amplitude based frequency response simulation in Abaqus
The discussion centers on setting up an amplitude-based frequency response simulation in Abaqus, specifically applying a displacement of 0.2 mm at a concerned frequency of 100 Hz. It is noted that Abaqus does not allow nonzero displacements as boundary conditions in mode-based dynamic response procedures, meaning users must use base motion or apply a force instead. The original poster seeks guidance on how to configure the analysis and whether amplitude can be applied in steps over a frequency range of 0-200 Hz. A suggestion to search for existing resources on Abaqus frequency analysis is provided. Ultimately, the user decides to proceed with applying a force for the simulation.
Sam George
TL;DR Summary
Enforce displacement in Frequency Response Simulation
Hi,
I have inputs like displacement of a driving mechanism and then the frequency of concern .
Displacement: 0.2 mm
Concerned Frequency: 100 Hz
I would like to evaluate a part with the input displacement applied to a node and not as base excitation.
It can be sweep over the frequency range 0-200Hz
How do we set it up in Abaqus, can we give amplitude in steps over the frequency range?
Please guide me with a link or syntax on how to proceed with the analysis setup.
Regards,
Sam George
Here’s a quote from Abaqus documentation (chapter about SSD analyses):
It is not possible to prescribe nonzero displacements and rotations directly as boundary conditions in mode-based dynamic response procedures. Therefore, in a mode-based steady-state dynamic analysis, the motion of nodes can be specified only as base motion; nonzero displacement or acceleration history definitions given as boundary conditions are ignored, and any changes in the support conditions from the eigenfrequency extraction step are flagged as errors.
So you have to either use a base motion BC or apply a force instead.
Likes Sam George and berkeman
Thanks for the reply, I think I will have go with using Force.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
