Amplitude Modulation Phenomona
In summary, the nature of amplitude modulation in regards to sound is that at higher speeds, the carrier starts to produce new frequencies known as sum and difference sidebands. These sidebands are created due to the fast modulation causing beats to shape the signal. The energy in the sidebands does not depend on the modulation frequency and the cochlea in the inner ear is responsible for perceiving different frequencies by stimulating different hair cells. When the sidebands are too close to the carrier, it becomes difficult to discern them due to the proximity of stimulated hair cells.
dmorr
Hey Everyone,
Can someone explain to me the natural of amplitude modulation in regards to sound. As in one modulator frequencies' amplitude modulating the amplitude of a carrier frequency. Because at low frequencies the modulator only affects the carrier in a way that makes its volume go up and down like tremolo (0.5hz). But at higher speeds like when the carrier is being modulated at 65hz the carrier starts to produce new frequencies known as sum and difference.
Why? What is the nature of this process that makes it happen? Why do you start to hear new frequencies just by turning the volume up and down of a signal at super high speeds?
The product of a small amplitude modulation on a carrier can be represented by [itex] \left(1+A\cos\omega_1t \right)\cos\omega_2t [/itex]. This can be rewritten as
[tex] \left(1+A\cos\omega_2t \right)\cos\omega_1t=\cos\omega_1t +A\cos\omega_2t\cos\omega_1t =\cos\omega_1t + \frac{A}{2} \cos\left(\omega_1-\omega_2 \right)t+\frac{A}{2} \cos\left(\omega_1+\omega_2 \right)t [/tex]
So the tremulo modulation produces sum and difference sidebands at any amplitude modulation frequency. So not being able to hear the sidebands as new frequencies might be just due to sound perception (see http://en.wikipedia.org/wiki/Psychoacoustics.)
Ok, I understand that the sidebands wouldn't be audible to the human ear as they would be only a few hz or less away from the carrier at low volumes.
However, I still can't explain why it happens this phenomena happens, because I don't know how to do trigonometry, so I can't see it from the numbers' perspective.
Could you explain to me where the sidebands get their energy from? Do they take away energy from the carrier the farther they start to move away? Do the sidebands get created because the modulation is so fast that the beats start to shape the signal fundamentally, as opposed to them being so wide that the tone of the carrier is much more clear?
thanks everyone.
The energy in the sidebands does not depend on the modulation frequency. In the above equation for the sidebands, the power in the three frequencies (carrier, lower sideband, upper sideband) is proportional to 1 + A2/4 + A2/4. So a higher amplitude modulation increases power, but changing the frequency of modulation does not.
The cochlea in the inner ear is a mechanical spectrum analyzer, in the sense that different frequencies stimulate different hair cells. This is due to the shape of the cochlea, and its stiffness gradient along its length. Different frequencies have different resonant excitation sites, and excite different hair cells. I can only surmise that when the sidebands are too close to the carrier, the stimulated hair cells are too close to the hair cells stimulated by the carrier, so discerning the sidebands becomes difficult.
Amplitude modulation is a type of modulation that involves changing the amplitude of a carrier signal in response to a modulating signal. This phenomenon occurs naturally in sound waves when the amplitude of a sound wave is modulated by another sound wave, resulting in changes in loudness or volume.
At low frequencies, the modulator only affects the carrier by causing it to fluctuate in loudness, similar to a tremolo effect. However, at higher frequencies, the modulator's amplitude changes become more rapid, resulting in the production of new frequencies known as sum and difference frequencies. This is due to the nature of sound waves and how they interact with each other.
Sound waves are made up of compressions and rarefactions, which are regions of high and low pressure. When two sound waves intersect, their compressions and rarefactions can either reinforce or cancel each other out, resulting in changes in the overall amplitude of the sound wave. This is known as interference.
In the case of amplitude modulation, the modulating signal is causing changes in the amplitude of the carrier signal, resulting in areas of reinforcement and cancellation when the two signals intersect. This creates new frequencies that were not present in either of the original signals.
The reason why these new frequencies are only heard at high modulation speeds is due to the rate at which the amplitude changes occur. At low speeds, the changes are too slow to create noticeable changes in the overall sound. But at higher speeds, the changes happen rapidly enough to create new frequencies that are audible to the human ear.
In conclusion, the nature of amplitude modulation is rooted in the physics of sound waves and how they interact with each other. The modulation process causes changes in the amplitude of the carrier signal, resulting in the production of new frequencies through interference. This phenomenon is what allows us to hear a range of different sounds and effects in music and other forms of audio.
Related to Amplitude Modulation Phenomona
What is Amplitude Modulation Phenomena?
Amplitude Modulation Phenomena is a method of encoding information onto a carrier wave by varying its amplitude in accordance with the information being transmitted. This technique is commonly used in radio broadcasting and is a form of analog modulation.
How does Amplitude Modulation Phenomena work?
Amplitude Modulation Phenomena works by combining a carrier wave, which has a constant frequency, with a modulating signal that contains the information being transmitted. The amplitude of the carrier wave is then varied in proportion to the amplitude of the modulating signal, creating a new signal that contains both the carrier wave and the modulating signal.
What are the advantages of using Amplitude Modulation Phenomena?
Amplitude Modulation Phenomena has several advantages, including its simplicity and compatibility with existing infrastructure. It also allows for a wider range of frequencies to be transmitted, making it useful for long-distance communication.
What are the drawbacks of Amplitude Modulation Phenomena?
One of the main drawbacks of Amplitude Modulation Phenomena is its susceptibility to noise and interference, which can distort the transmitted signal. It also has a limited bandwidth, meaning it cannot transmit a large amount of information compared to other modulation techniques.
What are some real-world applications of Amplitude Modulation Phenomena?
Amplitude Modulation Phenomena is commonly used in radio broadcasting, where it allows for the transmission of audio signals over long distances. It is also used in amplitude-shift keying, a technique used in digital communication systems such as Bluetooth and Wi-Fi. Additionally, it is used in some medical devices, such as electrocardiograms, to transmit data wirelessly.
  • Electrical Engineering
  • Classical Physics
  • Other Physics Topics
