Amplitude of a stationary wave
In summary, in a stationary wave, each point has a fixed amplitude that differs from the adjacent point, with nodes having zero amplitude and antinodes having the highest. This is in contrast to a progressive wave where all particles have the same amplitude and the wave moves as it continues to interfere. This is due to the momentary formation of a stationary wave.
Josielle Abdilla
50
Does each point in a stationary wave change its displacement and hence it's amplitude? If yes, why is this so? However, why does the amplitude at the node and antinode remains zero and maximum respectively? Does the above have to do with the fact that all the formation of a stationary wave is momentarily? What other dissimilarities stand between a progressive and a stationary wave?
Thanks :})
Each point on a stationary wave has a fixed amplitude that is different from the point next to it. Nodes have zero amplitude, antinodes have the largest amplitude than any other point.
What about in a progressive wave, do all particles have same amplitude?
However, the wave moves as the progressive waves continue to interfere, hence why shouldn't the amplitude change?
Related to Amplitude of a stationary wave
What is the amplitude of a stationary wave?
The amplitude of a stationary wave is the maximum displacement of a particle from its equilibrium position in a standing wave pattern.
How is the amplitude of a stationary wave measured?
The amplitude of a stationary wave is typically measured in meters (m) or centimeters (cm) using a ruler or other measuring device.
What factors affect the amplitude of a stationary wave?
The amplitude of a stationary wave is affected by the frequency and wavelength of the wave, as well as the properties of the medium through which the wave is traveling.
Can the amplitude of a stationary wave change over time?
No, the amplitude of a stationary wave remains constant over time. However, the amplitude of a traveling wave can change as it propagates through a medium.
What is the relationship between amplitude and energy in a stationary wave?
The amplitude of a stationary wave is directly proportional to the energy of the wave. This means that a higher amplitude wave carries more energy than a lower amplitude wave.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
16K
