Amplitude of an electromagnetic wave
In summary, amplitude is meaningless when considering photons, and it determines the intensity or brightness of an EM wave only when considered as a wave.
jaydnul
558
Lets take visible light for example. The frequency/wavelength determines the amount of energy and the type of wave(micro,radio,gamma ect.) The intensity or brightness is determined by the amount of photons. So what does the amplitude determine?
The intensity of an EM wave is written in terms of the amplitude:
[tex]
I=cn \frac{\epsilon_0}{2}\left|E_0\right|^2
[/tex]
so these aren't really independent things.
If you know it's energy then you are treating it as a single photon. Amplitude is meaningless.
If you know it's wavelength then you are treating it as a wave. As an EM wave it has both an E and an M component, each has it's own amplitude, the ratio of the E and M amplitudes is the impedance Zo of the material through which the EM wave is propagating. For free space Zo = 120 * Pi
This is according to the quantum view of light.
It determines the intensity or brightness, in the classical view of light.
If you want to consider photons at the same time as waves then you have a problem. A photon is not just a small point. It is just an amount of energy that the wave is carrying - or, at least, with which the wave interacts with objects. In pretty well every respect, it is the wave nature that dominates - except when there is an interaction involved. Any wave will not interact with a 'system' instantaneously. It takes time for the receiver (atom, molecule or TV set) to respond - several, or even many cycles of the wave are involved (depending on the 'Q' of the system) so how can this relate to a model involving a 'shower' of little photons, each one with its own 'phase'? This is a mixed model and it is neither fish nor fowl but I understand that it is attractive at a stage in the learning of the way EM works, despite being not very fruitful (imho).
Related to Amplitude of an electromagnetic wave
1. What is the amplitude of an electromagnetic wave?
The amplitude of an electromagnetic wave refers to the maximum value of the electric and magnetic fields that make up the wave. It is a measure of the strength or intensity of the wave.
2. How is the amplitude of an electromagnetic wave related to its energy?
The amplitude of an electromagnetic wave is directly proportional to its energy. This means that a wave with a higher amplitude will have more energy than a wave with a lower amplitude.
3. Can the amplitude of an electromagnetic wave be changed?
Yes, the amplitude of an electromagnetic wave can be changed by manipulating the electric and magnetic fields that make up the wave. This can be done through various means, such as changing the strength of the source or using devices to amplify or dampen the wave.
4. What happens to the amplitude of an electromagnetic wave as it travels through space?
The amplitude of an electromagnetic wave remains constant as it travels through space, assuming there are no external factors affecting it. This is known as the law of conservation of energy, which states that energy cannot be created or destroyed, only transferred or transformed.
5. How does the amplitude of an electromagnetic wave affect its frequency and wavelength?
The amplitude of an electromagnetic wave does not affect its frequency or wavelength. These properties are determined by the source of the wave and the medium through which it is traveling. However, a wave with a higher amplitude may appear brighter or more intense, but this does not change its frequency or wavelength.
  • Electromagnetism
  • Electromagnetism
  • Classical Physics
  • Classical Physics
  • Electromagnetism
