An age of the Universe around 20 billion years
In summary: In summary, the Hubble sphere is the radius at which light would never reach us because the speed of light is faster than the recession speed of the universe.
yheyman
Is it coincidental that the Hubble Sphere, in light years, is approximately the age of the universe computed as 1/Ho (13.7 billion years)?
If the recession speed exceeds the speed of light, the photon would never reach the observer, this is why there exists a horizon of the visible Universe (the Hubble sphere), beyond which light would never reach us. Historically the age of the Universe was computed from the loockback time between a redshift zero and infinity, which yields 1/Ho. Note that this measure gives the lookback time to the Hubble sphere because the redshift must converge towards infinity at the horizon of the visible Universe. Here is a reference showing the calculations with a De Sitter Universe (http://www.jrank.org/space/pages/2440/look-back-time.html). Another reference where the age of the Universe is computed with the look-back time between a redshift of zero and infinity: http://www.mpifr-bonn.mpg.de/staff/hvoss/DiplWeb/DiplWebap1.html . See A.36 et A.37.
Using another approach we can show that an apparently steady Hubble coefficient in the light travel distance framework is equivalent to a time-varying Hubble coefficient in the Euclidean framework of order two (i.e. Universe expanding at a steady acceleration pace). This approach gives an age of the Universe of about 20-25 billion years. This figure is compatible with the age of the Universe obtained from the datation of old stars. According to Chaboyer (1995) who analysed metal-rich and metal-poor globular clusters, the absolute age of the oldest globular clusters are found to lie in the range 11-21 Gyr. Bolte et al. (1995) estimated the age of the M92 globular cluster to be 15.8 Gyr. Th/Eu dating yields stellar ages of up to 18.9 Gyr (Truran et al., 2001). A paper describing this appoach is available online: http://fr.calameo.com/books/00014533338c183febd92
Space news on Phys.org
It's not a coincidence, it's just a trivial consequence of the definition of the Hubble constant. The Hubble constant is defined by fitting a slope Ho to a graph of v versus r, where r is the proper distance ( https://www.physicsforums.com/showthread.php?t=506990 ). That means we define Ho by using v=Hor, so if you plug in v=c you trivially get r=1/Ho.
No, this is incorrect: https://www.physicsforums.com/showthread.php?t=506987 The Hubble sphere that you're referring to is smaller than the observable universe.
My argument why the redshift converge to infinity at the Hubble sphere is the following: The main hypothesis for the development of a model for the motion of the photon in an expanding space, is that the speed of light is frame-independent. Considering redshifts, this means that the relative movement of a light source does not change the speed of light emitted; however, it does add or subtract energy. This change in energy level changes the frequency of the source of light, and not the speed. When the recession speed reaches the speed of light, all energy transmitted to the observer is being removed, and the corresponding wavelenght tends to infinity according to Planck law. The cosmic microwave background is a good example. It is very close to the Hubble sphere and its redshift is about 1000.
Your description would be correct according to special relativity, but special relativity isn't valid for cosmology.
Do you have background in general relativity at a mathematical level? If so, then you should be able to follow the calculation given in the FAQ entry linked to from #2, but please feel free to ask questions if there are steps you don't understand.
If not, then here is an article that attempts to explain the ideas without assuming any mathematical background in GR: http://www.mso.anu.edu.au/~charley/papers/LineweaverDavisSciAm.pdf
I would first like to commend the author for their thorough research and providing multiple sources to support their claims. The topic of the age of the universe is a complex and constantly evolving field of study, and it is important to consider all available evidence and approaches.
In response to the question of the coincidence between the age of the universe and the Hubble sphere as measured in light years, it is important to note that this is not a coincidence but rather a result of the relationship between the expansion rate of the universe and the speed of light. As the author mentions, the Hubble sphere represents the boundary of the visible universe, beyond which light has not had enough time to reach us due to the expansion of the universe. Therefore, it is expected that the age of the universe and the Hubble sphere would be related in some way.
The author also mentions the use of different approaches to calculate the age of the universe, such as the lookback time between a redshift of zero and infinity, as well as the use of Euclidean frameworks. These approaches may yield slightly different results, but they are all based on the same fundamental principles and evidence. It is important to continue exploring and refining these methods in order to obtain a more accurate understanding of the age of the universe.
Furthermore, the evidence from the dating of old stars also supports the idea of an age of the universe around 20 billion years. This is consistent with our current understanding of the formation and evolution of the universe.
In conclusion, the relationship between the age of the universe and the Hubble sphere is not a coincidence, but rather a result of the expansion of the universe and the speed of light. While there may be slight variations in the calculated age of the universe, the evidence from multiple sources supports an age of around 20 billion years. As scientists, it is important to continue studying and refining our understanding of the age of the universe in order to gain a deeper understanding of our place in the cosmos.
Related to An age of the Universe around 20 billion years
1. How do scientists determine the age of the Universe to be around 20 billion years?
Scientists use a variety of methods, including observing the expansion rate of the Universe, the cosmic microwave background radiation, and the ages of the oldest stars and galaxies, to estimate the age of the Universe. These methods all point to an age of around 20 billion years.
2. Has the estimated age of the Universe always been around 20 billion years?
No, the estimated age of the Universe has changed over time as scientific understanding and technology have improved. In the early 20th century, the age of the Universe was estimated to be around 2 billion years, but as more evidence was gathered, the age increased to around 20 billion years.
3. How accurate is the estimated age of the Universe?
The estimated age of the Universe is currently believed to have an uncertainty of around 1-2 billion years. However, as scientific methods continue to improve and new evidence is gathered, this accuracy may improve in the future.
4. What implications does an age of 20 billion years have on our understanding of the Universe?
An age of 20 billion years suggests that the Universe has been expanding and evolving for a very long time. This allows for the formation of galaxies, stars, and planets, and provides a timeline for the development of the Universe as we know it.
5. Could the estimated age of the Universe change in the future?
Yes, as new evidence is gathered and scientific methods continue to improve, the estimated age of the Universe may change. However, it is unlikely that there will be significant changes in the near future as the current estimate is supported by a wide range of observations and experiments.
  • Cosmology
  • Astronomy and Astrophysics
  • Cosmology
  • Cosmology
  • Cosmology
